March 27th, 2013, 04:59 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): Getting the 2008-2012 Ninja 250r Posts: 4
KOSO RX-2 Nina 250r Question PnP
I have a question if i buy the plug and play kit i know you install the 2 sensors, the oil and the water/radiator one. My question is can i just install the oil one and not radiator one, and the gauge would work fine? Obviously the water sensor wouldnt work but would everything else work? The reason i dont want to install the water one is because i'm afraid that i will mess up on the cutting of the hose in half and mess up my radiator....
Thanks for reading my topic ~Michael |
March 27th, 2013, 05:15 PM | #2 | |
Bass Master General
If you take the hose off and put it in a table vice and use a junior hack saw you can get a very good clean cut, like anything it's the prep and time taken that leads to a good result, I am fairly sure the device will work without knowing how hot your radiator is. |
March 29th, 2013, 12:20 PM | #3 |
So if i take off the hose where do i know to cut? in half?
March 29th, 2013, 12:47 PM | #4 |
Fast-Guy wannabe
MOTM - Jan '13
The blue thing is the Koso sensor and the large grey thing is a thermo-bob unit(that's where you thermostat is now) you want to place the sensor anywhere in this hose on the right side of the bike because its your return line and it will tell you the temp of the water coming out of the motor. I would install the Koso unit as far forward(behind the termostat but as far forward as possible) as you can. It's not that critical as long as you get it in there. Also try to get it into as area of strait tubing to make your life easier.
If you have some fiberglass insulation wrap it around the Koso unit to keep the ambient air temp for lowering your reading. This is not nessisary but without it just know that your temp reading will probably be about 10-20F low. I love my temp sensor so the idea of not installing it when you have it it just blasphemy. |
April 1st, 2013, 05:25 AM | #5 |
Join Date: Nov 2012 Motorcycle(s): 2009 Ninja 250R Posts: 26
Maybe you haven't looked at this yet? This video serves as a GREAT reference for ya.
April 1st, 2013, 05:58 AM | #6 |
Bass Master General
Hmm, the term "plug and play" has to be spread very thin on this one.
With the amount of cutting required and installing of new sensors it's very much not a drop in unit, nor would I use the term "plug and play" for something that needs a lot more attention then simply plugging it in, and using it as it is. |
April 1st, 2013, 06:30 AM | #7 | |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
EDIT: Not to mention that video couldn't break it down to any more simpler steps. I watched it because I'm buying one and wanted to see how it was done. After watching it I'm sure i could of figured out how to do that all myself by just looking at the parts. The only unsure part i would of been stuck on was where to put the coolant sensor in line. |
April 1st, 2013, 08:11 AM | #8 |
Bass Master General
You forgot you'll have to install the speed sensors or mechanical to digital adaptor, my point isn't on complexity, but rather the title of plug and play being misleading due to the fact it's not plug and play if you need to void your waranty by cutting into hoses and instal about three after market sensors, some of which require hacking the stock system.
If I could take the old one out, plug a new one in, sure, plug and play by the very definition, but this kit is going to take a lot more than that, and it annoys me that they market it is plug and play. |
April 1st, 2013, 02:23 PM | #9 | |
April 1st, 2013, 02:24 PM | #10 |
So if i was to get a 2008 ninja 250r, could someone send me a link to a website where i can buy a extra hose for the radiator just in case i fu*k up? lol
April 1st, 2013, 05:27 PM | #11 |
Yeah true I guess. But it's stated as plug and play probably because it's about as plug and play as it can be. The sensors, for the most part, are extra. The only "hacking" of the system is the coolant temp and that hose can be replaced if need be. I don't know how much it is at a parts store but you can always buy one first and hack that. Then if you ever wanna take your bike in then put the stock one back in. Granted they probably couldn't tell the difference between the stock hose or the one you bought. But everyone's mechanical ability is different so I guess "plug and play" describing a kit is kinda wrong when there's things other than plugging in involved.
And Michaelclaw, there's a stickied thread with a bunch of oem parts sites listed. Try there. |
April 16th, 2013, 08:19 PM | #12 | |
You can order one of those complete hose kits on eBay that come in fancy colors. |
April 16th, 2013, 08:27 PM | #13 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
you do not have to install either water or oil temperature gauges. I didnt and the other features work great
April 16th, 2013, 08:27 PM | #14 | |
Koso Rx-2 Gauge for 2008+ 250R | Yaozer | Motorcycle-related | 26 | July 24th, 2014 08:16 AM |
KisanTech Pathblazer PnP FS | Floki | Motorcycle-related | 0 | April 30th, 2014 08:22 AM |
Ecotrons and Koso Question | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 19th, 2012 05:07 PM |
Koso gauge install question | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 17th, 2012 01:54 PM |
HID PnP Kit With Angel Eyes | wayanlam | 2008 - 2012 Ninja 250R Farkles | 23 | July 23rd, 2011 11:32 PM |
