Old April 10th, 2012, 08:26 PM   #241
icbm
icbm's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo
Originally Posted by Rexbo View Post
Yep the 9.4 kg/mm spring is way too stiff. Thats why I swapped on the lighter 8.1kg/mm spring and now it works out REALLY well.
I put on the GSXR shock just recently. I haven't ridden it yet as I have the bike at my friend's shop to pull the frame at the neck to straighten it out. Anyhow, I am 230lbs naked and sitting on it initially, I will have to adjust it as well to soften it up a bit. I made my own dogbones with the 158mm eye to eye suggestions.
The forks I did from Racetech I set up for 215lb naked rider weight(.80kg springs) with emulators. I probably will need to adjust it a little to even out the rear shock. We will see.
icbm is offline   Reply With Quote
Old April 10th, 2012, 09:14 PM   #242
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
I found the racetech website to be very useful to calculate approximate rear spring rates if you're curious what would work better.
Rexbo is offline   Reply With Quote
Old April 10th, 2012, 09:30 PM   #243
icbm
icbm's Avatar
Yea I used it but Racetech asked me all the questions when I had them completely do the forks for me. Their site says 9.419kg/mm for road racing. The stock spring is 9.3kg/mm. So the GSXR is rated the same right?
Right now the bike is stripped of a lot of weight so until I put everything back on, I'll set Sag from there and see. I think with my weight being 235-250lbs suited the shock will work good.
Old May 20th, 2012, 06:15 PM   #244
Ritter
Ritter's Avatar
Motorcycle(s): Ninja 250r BSA Lightning, Chinese something
I just noticed your friend is running the number plate 46.
Ritter is offline   Reply With Quote
Old August 6th, 2012, 02:56 AM   #245
psych0hans
psych0hans's Avatar
Hey Steve, do you know if the 2008 GSXR 600 shock would work as well? Or does it have to be a 2006-2007 shock? Thanks in advance.
Old August 7th, 2012, 10:44 AM   #246
abhijitz
Motorcycle(s): Many Two Wheels ..
The info is all in post #186
http://www.ninjette.org/forums/showt...&postcount=186
You need 06-09 gsxr 600 shock and spring from 03-04 gsxr 1000 with collars/spacers. (or custom spring from racetech). You will also need Steve's linkages to compensate the height drop. Since i cannot use aftermarket linkages in my production race class, i ditched the gsxr shock for RPM 2-way shock [stock ride height] from Taiwan (sold by @samw - SportisiMotorSport).
fyi - As several folks from India asked me about the 250 build, i asked PerformanceMotorcycleStore at Bombay to talk to Sportisi & RPM but they did not seem to be interested.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old August 7th, 2012, 11:49 PM   #247
psych0hans
psych0hans's Avatar
Thanks for the reply Abhijit. I honestly wouldn't be looking at this mod, if I had the 360$ + shipping to shell out for the aftermarket shock. From what I understood from other DIYs is that it really isn't all that complicated, and you can use the stock GSXR spring... I really had no idea about the additional Spring/collars/spacers etc... I will get Steve's linkages though, makes sense to do so.
Old August 8th, 2012, 08:50 AM   #248
abhijitz
If you buy Racetech spring matched to your weight, you will not need the additional spacers/collars. If you re-use 03-04 gsxr 1000 spring, you will need it.
It is very easy to do. A change from Steve's method I did was, reuse the top eyelet from the stock shock as i did not like thinning the material on the gsxr shock. But, then disadvantage is, you damage your stock shock (no biggie - you can buy the OEM top eyelet for 11 bucks)
Now, keep in mind, all this spring discussion is based on weight. I weigh 172lb now and gsxr 600 spring was too hard on me. I dont know your weight so you may be good with the stock spring (who knows).
Most important, if you are planning on racing, do check with your local club if they allow modification to the linkages in their respective production class.
This is a great mod at budget price if done right.
Old August 8th, 2012, 10:34 AM   #249
psych0hans
psych0hans's Avatar
Hey @abhijitz Thanks for the valuable input. I weigh in at about 155-160lbs without gear, so I'm assuming it might go up to 170-175lbs with. I'm not likely to race the bike, my main aim is to get it as close to track ready and a super sports as possible. I've already bought the following for the same : -
1) Gold valve emulators.
2) Going to fab my own pre load adjusters.
3) SV650 clipons.
The only things I need now are rearsets, GSXR shock and a new set of tyres... Will keep getting things as I have the money ready. Sometimes I wish I was in the US just so I could race my ninjette... lol
Old August 11th, 2012, 08:43 AM   #250
Rexbo
Rexbo's Avatar
Go get some PVC or metal pipe of the right diameter and cut them into 5 or 10 mm lenghts, and just find the right preload that works for you! Also don't forget to play with oil level to get the forks feeling better.
Old August 22nd, 2012, 07:06 PM   #251
pjed
pjed's Avatar
Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900
Got the gixxer 600 shock installed today with a spring off of a 1000 using Rexbo's dog bones. I had to grind the swing arm quite a bit to make sure the spring cleared but I think it's good . Thanks to Rexbo for his input. Can't wait to see what difference it makes!
pjed is offline   Reply With Quote
Old August 22nd, 2012, 07:37 PM   #252
psych0hans
psych0hans's Avatar
@pjed why did you have to grind the swingarm? From what other DIYs I've seen, no one has had to grind the swingarm...
Last futzed with by psych0hans; October 1st, 2012 at 04:11 AM.
Old August 22nd, 2012, 07:58 PM   #253
pjed
pjed's Avatar
Not sure what spring and dog bones people on other DIYs used. In my case, I think Rexbo's dog bones moved the bottom linkage and for sure the gixxer 1000 spring is wider. The spring actually touched in two places and I couldn't get enough clearance just by spinning it.
Old August 23rd, 2012, 03:55 AM   #254
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Hmmm, interesting note about the linkage movement. Rexbo did you have to do something similar with your links?
Old October 5th, 2012, 11:32 AM   #255
psych0hans
psych0hans's Avatar
Something for the guys installing gsxr shocks... You can use a similar arrangement to this and still be legal, while maintaining stock height.
Old October 5th, 2012, 12:05 PM   #256
Rexbo
Rexbo's Avatar
I did. the 1000 spring is a larger diameter, but if you use a 600 or the OEM shock you shouldn't need to touch the swingarm.
Old October 5th, 2012, 04:40 PM   #257
cuong-nutz
cuong-nutz's Avatar
I'm trying to see if I can swap out the spring base plate with something thicker/taller to make up for the height difference.
HalfFast Racing Team
Old October 5th, 2012, 11:35 PM   #258
cuong-nutz
cuong-nutz's Avatar
GSXR600 spring is taller than the GSXR1000 spring
The springs get wider from top to bottom
1000 spring is wider than the 600
05/06 gsxr600 spring
ID 60.2mm top
ID 64.3mm bottom
OD 83mm top
OD 86.5mm bottom
Length 196.5mm
05/06 gsxr1000 spring
ID 57.2mm top
ID 60.3mm bottom
OD 77mm top
OD 82.5mm bottom
Length 190.5
Spring thickness on both is 11.4mm
Lower shock clevis inner spacing 30mm
Stock Ninja 250 dog bone spacing is ~74mm
Last futzed with by cuong-nutz; October 6th, 2012 at 11:49 AM.
Old October 6th, 2012, 09:03 AM   #259
Rexbo
Rexbo's Avatar
good info!
Old October 6th, 2012, 09:14 AM   #260
psych0hans
psych0hans's Avatar
Pics, when you manage
Old October 6th, 2012, 12:45 PM   #261
cuong-nutz
cuong-nutz's Avatar
The shaft size on the 1000 shock is too large so it won't work with 600 shock so I'm thinking maybe the base off an 04-05 600 may work. The base looks the same as the 1000 but I don't know what the shaft size is.
Old October 6th, 2012, 07:31 PM   #262
psych0hans
psych0hans's Avatar
Why dont you try fabbing one up from an alu square bar? Doesn't have to be fancy, just got to work.
Old October 7th, 2012, 12:57 PM   #263
cuong-nutz
cuong-nutz's Avatar
I have not taken apart the base with the adjuster to see if it can be modified or extended.
Old October 11th, 2012, 10:14 AM   #264
cuong-nutz
cuong-nutz's Avatar
@Rexbo, So Steve, The 156mm dog bones will raise the rear end up to stock height or higher with the GSXR shock? I need to know before I start hacking some ZZR600 links
Old October 11th, 2012, 10:31 AM   #265
Rexbo
Rexbo's Avatar
Should be higher than stock even with the shorter gsxr shock
Old October 12th, 2012, 05:46 PM   #266
cuong-nutz
cuong-nutz's Avatar
Did a mockup with the gsxr shock. With the stock linkage and 1000 spring, it looks like it clears everything after doing numerous bounce tests. Even just bouncing the bike, The gsxr show really shows how bad the front needs work.
not quite sure how abhijitz reused the stock bolt sleeve on the gsxr shock unless he heated up the sleeve and melted it though to fit in the gsxr.
Old October 12th, 2012, 05:57 PM   #267
abhijitz
GSXR shock head was heated and the inner metal sleeve was pressed out. (same with the 250 stock shock) The rubber circumference turned rough. Then the metal inner sleeve from the 250 shock was pressed in. (Before pressing in, silicone was smeared on the rougher inner edge. The sleeve secured rock solid and thereby the thickness of the sleeve was not compromised.
[The complete Ninja 250 shock sleeve assembly can be purchased for 12 bucks]
Old October 12th, 2012, 08:35 PM   #268
cuong-nutz
cuong-nutz's Avatar
Yeah, that's the only way I could figure that you did. I was under the initial impression that you pressed out the whole bushing/sleeve and pressed it onto the gsxr shock. I realized you couldn't after I removed the stock shock.
Old October 15th, 2012, 10:16 PM   #269
psych0hans
psych0hans's Avatar
Can we use a ZX6r shock instead of a GSXR shock? I'm getting an 08' ZX6r shock for pretty cheap...
Old October 26th, 2012, 10:01 AM   #270
@Rexbo i'm wondering if you can tell me the effective rear wheel travel with this setup? iirc stock shock with stock knuckle is ~130mm, same with the gsxr shock? i know rear wheel travel on the gsxr is 135ish depending on year but im not sure if it runs a different ratio on the shock knuckle or not... nobody lists the ratios of the shock knuckles
Old October 26th, 2012, 02:33 PM   #271
Rexbo
Rexbo's Avatar
Enough. This isn't a dirt bike here!
Old October 26th, 2012, 02:42 PM   #272
Old October 26th, 2012, 04:07 PM   #273
Rexbo
Rexbo's Avatar
Haha enough as in enough suspension travel :P
Old November 11th, 2012, 04:40 PM   #274
1ER6F
#41 Noriyuki Haga
1ER6F's Avatar
Motorcycle(s): '10 250r Track Bike
Gettin our haterade on:
Funny that each of you are drinking Gatorade that is the same color as your bike!
1ER6F is offline   Reply With Quote
Old February 21st, 2013, 05:27 AM   #275
psych0hans
psych0hans's Avatar
I've installed my gsxr600 shock with adjustable dog bones with an eye-eye length of 150mm any idea how much is it going to raise my bike's rear? How can I measure it and what's the stock height? Cheers!!! @Rexbo
Last futzed with by psych0hans; February 22nd, 2013 at 03:13 AM.
Old April 14th, 2013, 12:30 AM   #276
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Bumping because there's good info in this thread.
It's too bad that all through Ninjette there is no one definitive DIY for installing the gixxer shock. Scattered notes and whatnot are the best I can find.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old April 14th, 2013, 08:31 AM   #277
Zombiphone
CVMA/AFM #72
Zombiphone's Avatar
Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike)
That doesn't sound like Steve
Zombiphone is offline   Reply With Quote
Old April 16th, 2013, 12:40 AM   #278
HotRedTurbo
HotRedTurbo's Avatar
Motorcycle(s): 2008 Ninja 250r, 2003 GSX R600
I agree. It seems that there are a few trying different things which makes it hard (at least for me) to see which yielded the best results.
Good info though and great site-very impressed on the level of ingenuity here. I’ve tried the GSXR shock and ran into the same issues others stated (lowered the rear ride height). I swapped back to stock shock and will be keeping up with the new ideas you guys are coming up with (diff spring combo, etc). Some of you need to get paid for all of this R&D work! Lol
HotRedTurbo is offline   Reply With Quote
Old April 16th, 2013, 06:59 AM   #279
Rexbo
Rexbo's Avatar
Its pretty straightforward:
1) Buy a 05-06 GSXR600 shock (resevoir fits)
2) Drill out the upper and lower eyes with a 12mm drill or 15/32" bit
3) Swap the spring with the spring from a 600/750/1000, whichever is closest to correct spring rate per the racetech calculator.
4) Buy my dogbones to lift the back of the bike way up high, and set sag.
5) Win.
Old April 16th, 2013, 08:38 AM   #280
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
5) Win.
Done on both my 250 and 300.
Unfortunately MRA production racing rules require me to use the stock rear shock on my 250.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Track Prep nickjpass Ninjettes At Speed 38 August 11th, 2014 08:13 PM
Paint prep.... ManOfGod General Motorcycling Discussion 21 May 11th, 2013 07:50 AM
2010 - Ninja 250r race prep 675Raisinator Motorcycle-related 1 December 26th, 2012 11:27 AM
Project: N250r Race prep racegunnr Pictures 19 January 3rd, 2012 10:00 PM
bike prep Miss Informed 1986 - 2007 Ninja 250R Tech Talk 3 March 14th, 2011 12:45 PM
