Old May 6th, 2018, 12:37 PM   #1
Duneger
Motorcycle(s): 1987 Honda Magna 2000 Buell M2 Cyclone 2006 Kawasaki Ninja EX250
2010 250 Engine Swap
Hello, I recently bought a 2006 ninja EX250F. It needed a new engine, so I did some research on the swap from a new gen engine to a pre-gen frame.
Everything is pretty much set except the breather tube on the top of the valve cover. I'm assuming its for a PCV system. Is that correct, can I just go out and get a generic PCV valve, tubing and attach it to my air box?
Duneger is offline   Reply With Quote
Old May 6th, 2018, 02:29 PM   #2
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Just block off the smog plate. Then its just like the pre gen cyl head.
Dave Wolfe is offline   Reply With Quote
Old May 6th, 2018, 02:41 PM   #3
It's not a PCV valve. The "PCV" breather is what goes from the gearbox area into the bottom of the airbox.
The top of the head has the KLEEN Air system... it's basically fresh air injection at the exhaust ports. Allows the cats some air for further burn, dilutes the mixture a little to make it look less bad with a sniffer. Plug it. Nothing bad happens.
Old May 6th, 2018, 04:58 PM   #4
Duneger
Uff-da, that could have been a waste of time. Thank you guys for the explanation and the suggestion!
Engine Swap help cpayton0 1986 - 2007 Ninja 250R Tech Talk 3 October 24th, 2017 03:19 PM
engine swap iflylow General Motorcycling Discussion 4 October 24th, 2017 12:30 PM
ninja 250 engine swap tellmewhy! General Motorcycling Discussion 11 May 25th, 2016 06:38 AM
Engine swap 2010 Ninja into a 1997 motorbikerx 2008 - 2012 Ninja 250R Tech Talk 2 November 5th, 2014 05:56 AM
86' engine swap Birthdayninja86 1986 - 2007 Ninja 250R Tech Talk 12 March 26th, 2012 08:30 AM
