Old May 11th, 2018, 09:54 AM   #1
sqeet
Motorcycle(s): 2010 Kawasaki Ninja 250
Yet Another Oil Leak Post
So, I think I screwed up big time... but hoping someone can tell me it's not true. Had to drain the oil to ship my bike across the country. Made it safely and uneventfully. Ready to prep it to ride again, so I decided to change the oil filter (bought it after 6k miles and no clue if the previous owner changed the oil at 6k). Get everything put back together (even used a torque wrench). I go to add the new oil and immediately it starts leaking from what looks like a crack here: https://d.pr/i/VQaA0B (image also attached, in case link doesn't work).
I'm hoping you can either a) tell me I'm wrong and it's an easy fix like the filter is loose or b) help me identify what the name of this whole piece is and if it'll be an easy repair/replacement.
Thanks!
sqeet is offline   Reply With Quote
Old May 11th, 2018, 10:00 AM   #2
Ralgha
Ralgha's Avatar
If that's really a crack and not just a scratch, I think it's a big time problem. However, are you sure it's coming from right there and not from the filter? Did you forget to install the o-ring, or might it have gotten pinched when you screwed it in? Did you smear the o-ring with a bit of oil before installing it?
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old May 11th, 2018, 10:25 AM   #3
sqeet
Just to be sure, I went and checked again. Wiped it clean and watched for the leak. It's definitely coming from that crack. Why do you say "big-time" problem? Is that the crankcase? Am I just hosed?
Old May 11th, 2018, 10:35 AM   #4
Ralgha
Ralgha's Avatar
Yeah, that's the crankcase. There may be a way to repair it, but I don't know enough about it to say how. Perhaps someone more knowledgeable knows a way.
Old May 11th, 2018, 11:24 AM   #5
Looks like crack, perhaps from being dropped. Is there flat-spot on bolt anywhere? Do you have photos without crack from before shipping? Perhaps shipper's insurance will cover it if it happened in transport.
Personally, I would drop engine, loosen surrounding case bolts, v-notch and weld it back up.
Old May 11th, 2018, 11:30 AM   #6
mgentz
Board Member
someone may have crushed or over-tightened the bolt that the crack (and seemingly another one) extends out from. If it truly is this, welding would be the best bet.
but....are you sure you put in a new o-ring for the filter plate? Was it the right size? My kit always comes with two versions....
Old May 11th, 2018, 12:16 PM   #7
sqeet
I'm sure. I'm pretty sure it was me who did that. I reached under blindly while putting the filter back on and must have tightened the wrong bolt w/ the torque wrench. And I used the right o-ring, the other one didn't fit. Unfortunately, I checked and the oil is definitely leaking from that crack. :facepalm:
So, welding is an option for this? Is that expensive? Anybody around the LA area have a reputable shop they love?
Old May 11th, 2018, 12:33 PM   #8
mgentz
Board Member
This sounds like I am beating a dead horse, but I think we need to be sure....
When you say that the oring did not fit, do you mean that it was too small or too large? I ask because you want to use the one that seems too large...and it does fit!
Old May 11th, 2018, 12:56 PM   #9
sqeet
I matched the size I put in, to the one I took out.
I also went out there this morning and wiped down the area around it and waited for the oil to leak again... and, unfortunately, it's definitely coming from the crack in the lower crankcase. I'm just going to have to call around and find out how much it's going to cost to get it welded closed properly.
Old May 11th, 2018, 01:26 PM   #10
How much torque did you use? I doubt any amount of torque can generate a crack that large, that's A LOT of material to break, 3-4 inches of 5-6mm thick aluminium? Steel bolt would strip alloy threads well before being able to make that big of a break.
Definitely looks like an impact because one side of crack looks displaced about 0.5mm. Something had to not only break the case, but also have enough force to push one side inwards permanently by 0.5mm
Welding would be best and 100% for sure no-leak solution.
Old May 11th, 2018, 01:34 PM   #11
mgentz
Board Member
look at the crush washer on that thing! mushroomed around the bolt flange! definitely torqued the busienss out of that thing.
Oil leak Soundtrackzz 1986 - 2007 Ninja 250R Tech Talk 8 May 11th, 2017 11:14 AM
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
