Old May 31st, 2018, 05:31 PM   #1
NorthernNinja
Help dropped bolt in engine
yeah, i know, i'm really dumb. after rebuilding my engine i had it almost entirely back together when i realized i hadn't screwed on the coolant hose that bolts onto the back of the cylinders. when i tried to, i dropped one of the bolts down the hole. i don't remember where that hole goes or how deep it is. please help, i just want my bike back asap as it's my only vehicle.
NorthernNinja is offline   Reply With Quote
Old May 31st, 2018, 06:12 PM   #2
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
That only goes down to the bottom of the cylinder. It cant be more than a few inches down. The cylinder liners are so close together i doubt the bolt went anywhere.
Heck its probably stuck next to the starter where its hard to see.
Dave Wolfe is offline   Reply With Quote
Old May 31st, 2018, 06:20 PM   #3
A magnet on a string should get it, I'd think. The block is aluminum.
Old June 1st, 2018, 07:01 AM   #4
Grab bike and shake it upside down. Bolt will fall out from wherever it is.
Old June 1st, 2018, 08:51 AM   #5
mgentz
Board Member
the hole goes in and then around the cylinders. it is either right there at the end of the hole, or worst case, at the front of the motor.
The magnet idea is the best one. Again, worst case you will need to pull the back part of the bike off to get a better shot at the hole. Worse worst case, you pull the cylinder.
Old June 1st, 2018, 08:53 AM   #6
I would try a small telescopic magnet. Some have a cover that slides over the sides of the magnet so it only will attract on the very end, which is handy if there are any steel parts you need to go past.
Get a bright flashlight and see if you can see where it is.
A "gripper" with 4 wire "fingers" that come out of a cable housing (when you push the button on the end) is another option, but you would need to be able to see the bolt to use it.
Old June 1st, 2018, 09:53 AM   #7
Try fishing around with one of these: https://www.harborfreight.com/18-inc...net-37187.html
Old June 1st, 2018, 02:11 PM   #8
NorthernNinja
As always, thanks for being so helpful guys. I managed to fish it out with a mirror on a stick, a magnet on a stick, a coat hanger, and a flashlight, lol. I've got a full shop, and the engine was just apart, tools and stuff weren't really a concern, just didn't want to pull it back apart again. thanks everyone!
Old June 1st, 2018, 02:11 PM   #9
NorthernNinja
Also, Danno, i laughed way too hard at that
Old June 1st, 2018, 02:13 PM   #10
Glad you got it. I once dropped a piece of shim stock down my cam chain tunnel and it took longer than I thought it would to get it out with one of the pushbutton cable-claw things mentioned above.
Bent Engine mount bolt oompa General Motorcycling Discussion 2 April 15th, 2015 08:27 PM
Lost Front Engine Mount Bolt - Pics of damage inside hawker1693 1986 - 2007 Ninja 250R Tech Talk 56 August 26th, 2013 04:08 PM
Dropped Bolt in Gas Tank? Major or Minor Issue? JBinSD 2013 - 2017 Ninja 300 Tech Talk 19 July 15th, 2013 08:48 PM
Help! Dropped socket into engine... CmichRider 1986 - 2007 Ninja 250R Tech Talk 3 July 19th, 2011 03:55 PM
I Dropped my feeler gauge down into the Engine!!!!!! TheAmazingKickstand 1986 - 2007 Ninja 250R Tech Talk 18 August 7th, 2009 04:04 PM
