Old June 10th, 2012, 03:40 PM   #1
fizzer914
fizzer914's Avatar
Motorcycle(s): 2010 250 se
question about shimming those needles
ok i, had installed a jet kit from the dealer last year, bike runs great, i joined the forum and lookin at the DIY's it seemed easy just a b!tch to get the needles back in especially the left one and i was fore warned. so the question is i got is after i put the washer under the needle noticed an e clip and various slots in which to move the clip up or down. i put the washer in anyway not knowing if i could move the clip instead.
the bike runs fine no choke needed at startup now. i blasted around the block and all is good should i redo it and move that clip instead of the washer??? or just leave it alone??
fizzer914 is offline   Reply With Quote
Old June 10th, 2012, 03:44 PM   #2
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
The washer is the same as 1/2 of a clip move, so up to you if you need more or not.
NJ Ninjette is offline   Reply With Quote
Old June 10th, 2012, 04:46 PM   #3
the clip does the same as the washer. if your dealer put the jet kit in, its already tuned and adding a washer is making it worse. put it back to what it was before.
Old June 10th, 2012, 05:03 PM   #4
fizzer914
fizzer914's Avatar
well i also removed the snorkel....
besides that its like 80 deg and i dont need any choke the bike starts better im going to test it out now ill get back. im going to remove it and adjust the clip also the deush at the dealer messed up a diaphragm just how expensive r they?????
nuthin like doin sh!t 2X thanks for the input
Old June 10th, 2012, 05:05 PM   #5
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
If they messed up the diaphragm then they should be paying for it...?
Reyno2ac is offline   Reply With Quote
Old June 10th, 2012, 05:14 PM   #6
fizzer914
fizzer914's Avatar
right but how can i prove it any way im going there right after work and i will get mine i did electrical work in the mechanics house so i know hell do the right thing its east to over look if ur not careful it took me damn near 20min to get the good diaphragm in the groove as the fuukin spring and clearance issues. i was more worried about the stripping the screws.
Old June 11th, 2012, 03:12 AM   #7
fizzer914
fizzer914's Avatar
well thr ride is much better no more choke on to start the damn thing. starts up VERY easily when cold or cool! love it now i got to shim it properly and ill b good
Shimming same with Jetkit Needles? vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 1st, 2013 11:49 PM
DJ Needles instead of shimming mxman38 2008 - 2012 Ninja 250R Tech Talk 7 May 30th, 2012 07:09 PM
Shimming Needles @ NYC keeyu 2008 - 2012 Ninja 250R Tech Talk 25 August 17th, 2010 12:14 PM
Question about the washers to use when shimming the needles Kitdog 2008 - 2012 Ninja 250R Tech Talk 2 May 30th, 2010 12:38 PM
Shimming the needles question Tubesock 2008 - 2012 Ninja 250R Tech Talk 20 August 15th, 2009 12:17 PM
