Old July 24th, 2016, 11:00 PM   #1
Ryan_005
Ryan_005's Avatar
Suspension Setting
Curious, I am wondering what settings you guys have your suspension set at? I will put a template down below:
Weight:
Road Conditions:
Commute/race/travel??:
Setting:
"The most important thing is to have a good relationship with the bike... you have to understand what she wants. " ~Valentino Rossi
Understand, Unregistered ?
Ryan_005 is offline   Reply With Quote
Old July 25th, 2016, 09:09 AM   #2
daverdfw
Motorcycle(s): 2009 Ninja 250
Weight:
Road Conditions:
Setting:
This is a whole can of worms,
as for me since I am 220lb I have .90 front springs, RT emulators 15wt oil and preload adjusters, Rear shock is a GSXR 600 shock. The stock suspension is fine if you weight like 130lb.
daverdfw is offline   Reply With Quote
Old July 25th, 2016, 09:26 AM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
This should be called "configuration/mods".
The only setting a Ninja has is rear preload. The front is non-adjustable.
Goin' fast on slow bikes!
Old July 25th, 2016, 10:01 AM   #4
Ghostt
Ghostt's Avatar
Weight:
Road Conditions:
Setting:
220lbs with gear
Commute
Forks, .85kg/mm, 15w synthetic fork oil
Rear ZX600 shock, 15w synthetic oil, adjustable air pressure, BCB BIG BOY LINKS.
violente et ignorantia
ZX-2R BLOG
[RoadRUNNER] - MotoMojo: Setting Suspension Height Ninjette Newsbot Motorcycling News 0 March 4th, 2015 03:10 AM
[roadracingworld.com] - JRi Shocks And GP Suspension Team Up To Offer Suspension Pack Ninjette Newsbot Motorcycling News 0 November 14th, 2012 01:40 PM
[roadracingworld.com] - STM Suspension Holding Suspension Seminar June 25 In Colorado Ninjette Newsbot Motorcycling News 0 June 21st, 2011 10:10 AM
[sportrider - latest stories] - Secrets To Suspension: Setting Sag Ninjette Newsbot Motorcycling News 0 October 14th, 2009 06:40 PM
[motorcyclistonline] - Suspension Setup 101 Part I: Setting Sag Ninjette Newsbot Motorcycling News 0 June 19th, 2008 04:55 AM
