Old October 12th, 2023, 04:17 PM   #321
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
Good to see some of the old basic methods of removing frozen screws are being used...
these new guys would have tried to weld a nut to it ! HAHAHHAH
done right the easy out is by far the easiest method but it does require a straight hole...
and being a pilot jet the hole was already there you just had to enlarge it a bit...so the easy out would fit and start....
.... I've broken all of my small easyouts over the last 50 years so I would have to buy a complete set if I ran into that problem..... or just send it to you LOL
Bob.....
Old October 13th, 2023, 02:46 PM   #322
ducatiman
ducatiman's Avatar
happened on the pilot adjust screw, not the pilot jet. Frozen solid, started with a tiny hole, increased bit size till I achieved proper size listed on the #2 EZ out,
still a tricky removal process.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old October 13th, 2023, 05:20 PM   #323
Bob KellyIII
yah ! I bet it was....one slip and you destroy the carb...glad it was you and not me ! HAHAHAHAHHA ( I'ed be pricing a used carb if it was me !)
Bob......
Old October 15th, 2023, 10:34 AM   #324
ducatiman
ducatiman's Avatar
the VTX1300 carb is completed, with the exception of a new bowl "gasket" which i await delivery on.
Complicated Keihin single carb designed with both an accelerator pump and a decel valve. I've disassembled both and cleaned all their passageways along with the same old pilot, main circuits (which were previously clogged solid)
These should be fine runners once reinstalled.
Custom Carb Service
Old October 17th, 2023, 05:32 PM   #325
ducatiman
ducatiman's Avatar
an especially nasty set of EX500 carbs in house currently. Float valves frozen in place within their seats, black gook all over. Wow. Pics'll follow as i progress.
Custom Carb Service
Old October 20th, 2023, 06:57 PM   #326
ducatiman
ducatiman's Avatar
some progress, though not completed as yet
Custom Carb Service
Old October 23rd, 2023, 11:58 AM   #327
ducatiman
ducatiman's Avatar
and they are finally ......done. Both wet and air tested perfect, no leaks internal or external. Synched, estimated idle speed. Ready to go back home now.
Photo as received and completed.
Custom Carb Service
Old November 9th, 2023, 03:30 PM   #328
ducatiman
ducatiman's Avatar
the owner just called, whoever did the install missed attaching the vac hose onto the petcock.....once corrected the 1300 runs SUPERB!
Custom Carb Service
Old November 16th, 2023, 04:30 PM   #329
ducatiman
ducatiman's Avatar
been busy preparing my #113 EX500 carbset (my property based on trade-ins)
Actually removed a tiny pilot screw tip, broken off and solidly blocking its port. I'll post a pic when I can. These are a tough refurb, the pilot jet port on the other carb is solidly blocked, currently in ultrasonic, hopefully will clear it.
And, in the meantime, the electric motor has overheated/seized on my 12-15 year old shop vac. As its NLA to buy/replace as new...had no choice but to buy a new shop vac this morning, an integral supporting device used within my services.
Custom Carb Service
Old November 16th, 2023, 04:53 PM   #330
Bob KellyIII
What is it with shop vac's ? I've gone through 4 of them in my time so far
my latest is a Haart 3.5 gal for cleaning my pellet stove, so far so good
but all the rest the bearings in the motors went out.... it's like they were ALL put together with no grease on the bearings !
I am tempted to pull the one I have apart right now and grease it real good !
they all worked great for a short period of time...then promptly died as the bearing would ware out and allow the motor to wobble
once they start going into that wobble mode they can't get the RPM and are useless.......
I suggest you pull your brand new Shop vac apart and lube the bearings !
they should be tiny ball bearings but even those need lubed !
Bob..
Old November 17th, 2023, 06:56 PM   #331
ducatiman
ducatiman's Avatar
on my shop vac the motors' commutator windings were badly burnt.
Carbset #113 (though for EX500) will be released tomorrow, I believe.
Perfectly passed a wet test this afternoon, levels right on the money, no leaks internal or external.
Edited to add: totally finished #113 today, currently listed FS on the EX-500 website.
Custom Carb Service
Last futzed with by ducatiman; November 18th, 2023 at 04:36 PM.
Old November 19th, 2023, 04:38 PM   #332
ducatiman
ducatiman's Avatar
today, near finished a 250 set, wet test followed by final assembly to commence tomorrow. I'll post a pic or 2 then.
Custom Carb Service
Last futzed with by ducatiman; November 20th, 2023 at 01:23 PM.
Old November 20th, 2023, 01:25 PM   #333
ducatiman
ducatiman's Avatar
done, back in the mail already. Findings included swapped jet needles (as they are '09 L/R placement is critical), totally clogged mains/pilots and also 1 choke circuit clogged solid. All cleared/corrected now, should be bolt-on runners. I'll await owners report.
Custom Carb Service
Last futzed with by ducatiman; November 20th, 2023 at 02:59 PM.
[roadracingworld.com] - Yamaha VR46 Master Camp Video: Day Four Was A Special Day For Ninjette Newsbot Motorcycling News 0 May 26th, 2019 10:52 AM
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
[kropotkin thinks...] - IMS Press Release: A Day-By-Day Guide To What's On At The Red Ninjette Newsbot Motorcycling News 0 August 5th, 2014 09:30 AM
[motorcycledaily.com] - Max Biaggi Finishes First Day of Two-Day Ducati MotoGP Test ( Ninjette Newsbot Motorcycling News 0 June 6th, 2013 05:10 PM
[kropotkin thinks...] - Shots In The Dark, Day 4: Scott Jones, Race Day Ninjette Newsbot Motorcycling News 0 April 9th, 2013 03:50 AM
