June 26th, 2012, 06:14 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150 Posts: 146
JT Front Sprocket Question
Folks,
I just got a chain and sprockets for my 98. I want to make sure I put this thing on correctly. The JT front sprocket has a built-in spacer on one side, and is flat on the other side. The writing is on the side with the spacer. My first thought is that the spacer goes on the inside, but typically the writing on a sprocket goes on the outside. I'm about 99% sure I'm going to put the spacer (and writing) on the inside, but I thought I'd check with you guys first. Thanks,
Jim Moore Jax, FL |
June 26th, 2012, 10:20 AM | #2 |
You figure this one out Jim? This may help if not.
http://www.ninjette.org/forums/showthread.php?t=10273
June 26th, 2012, 01:59 PM | #4 |
Thanks. I haven't taken mine off yet, but that looks like a different set up from the pre-gen.
More like this: http://faq.ninja250.org/wiki/How_do_...nt_sprocket%3F
Jim Moore Jax, FL |
June 26th, 2012, 02:09 PM | #5 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
June 26th, 2012, 02:12 PM | #6 |
10 nm according to the other site. Not too much.
Jim Moore Jax, FL |
June 26th, 2012, 02:14 PM | #7 |
June 26th, 2012, 03:04 PM | #9 |
June 26th, 2012, 03:37 PM | #10 |
most bikes dont come with holes for safety wire or predrilled bolts. but thats why man invented the drill
June 27th, 2012, 04:45 AM | #11 |
Thanks for the info guys. I don't think I'm gonna drill them out and safety wire them, but I think I'm gonna use some blue locktite. Any reason not to?
Jim Moore Jax, FL |
Chain and sprocket question | Baron | 2008 - 2012 Ninja 250R Tech Talk | 12 | July 11th, 2014 01:35 PM |
Rear sprocket question | reroka | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 27th, 2014 09:36 PM |
Chain and Sprocket Question | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 25th, 2014 01:44 AM |
Sprocket question from a newbie | cryllyn | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 16th, 2012 10:25 PM |
Stupid Sprocket Question | demp | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 7th, 2010 01:32 PM |
