Old January 24th, 2014, 07:18 PM   #1
rasta
Your face
rasta's Avatar
12v stopped working
Noticed my phone wouldn't get charged anymore so I did some research on my bike. When I turn my bike's power on, I see the red light on the 12v turn on for a second or so before shutting off. This leads me to believe I have a weak connection in the back of my bike between the license plate light and my red/black wires from the 12v. I also believe I just need to remove my splices and connect the wires with some good ole solder. Does my trail of thought sound right to you?
Old January 24th, 2014, 08:09 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I always start these responses by saying I'm no electrician.
If everything else is working right, then yeah sounds like there is something loose with the connection on the 12v, either on the positive or the ground. I like checking the ground first to make sure that connection is solid. Then yeah check the positive. Depending on how you hooked them up they may have worked themselves apart.
Solder good, me like solder!
<-- Linky
Old January 24th, 2014, 08:44 PM   #3
rasta
Your face
rasta's Avatar
I soldered.......same problem. Maybe this means I suck at soldering.
Old January 24th, 2014, 08:53 PM   #4
NevadaWolf
NevadaWolf's Avatar
Or the problem is elsewhere.
Um, if it were me, my next step would be to test the 12v itself. Free it when all connections and use a spare wire with gator clips to hook it directly to the battery. If it fails still, the something is wrong with the 12v
If it passes, then there is something wrong at the point the wires connect. I'd try wiring them together and being extra careful to make a clean connection.
Just, that's what I'd do. But again, not an electrician so I stumble around blindly a lot.
<-- Linky
Old January 24th, 2014, 09:47 PM   #5
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Does your charger socket happen to have a fuse and if so is that fuse good?
Also check to make sure the ground wire(s) are secured to a clean, metal mating surface.
That's all I can think of right now as there really isn't a lot going on in the back of that bike wiring wise.
Old January 24th, 2014, 10:10 PM   #6
rasta
Your face
rasta's Avatar
Survey says....crappy USB connector. Took it out and plugged into my car and the same thing happened. So that's good news. Guess I didn't have to solder, but at least I have a better connection back there now. Coooool beans
Old January 24th, 2014, 10:12 PM   #7
TnNinjaGirl
Ms. Personality
Glad it was simple. Electrical problems are sometimes a biotch
Old January 24th, 2014, 10:13 PM   #8
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
did you crimp the lines? (nvm problem solved, but still that'll make the connection last much longer) just using electrical tape over solder, or worse nothing, is asking the connection to fail down the line
Old January 25th, 2014, 01:17 AM   #9
rasta
Your face
rasta's Avatar
Whoops I didn't technically crimp them beforehand, but I did twist them pretty well with some needle nose.
Turn signals stopped working. Insan3guy General Motorcycling Discussion 1 October 15th, 2013 10:17 PM
Tach stopped working? beta7 2008 - 2012 Ninja 250R Tech Talk 1 July 4th, 2013 09:31 AM
Blinkers just stopped working coluk33 1986 - 2007 Ninja 250R Tech Talk 8 May 6th, 2013 09:13 PM
tach stopped working -.- ajaygraci 2008 - 2012 Ninja 250R Tech Talk 23 March 31st, 2012 10:55 PM
Blinkers stopped working :( caps 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2011 10:54 AM
