July 29th, 2009, 09:17 PM | #1 |
Ninja fan
Join Date: Mar 2009 Motorcycle(s): 2004 Ninja 250, 2003 buell XB9R Posts: 46
replacing rear brakes
Is there a special caliper compression tool, or a simple trick? I got the new pads in but there is no space for the rotor. I've done disc brakes on cars, but this whole motorcycle maintenance is kinda new to me. Thanks a ton.
Muzzy full exhaust, Dynojet kit stage 2, Asiancycle front flush mouts, rear pod turn signals, rear fender delete. |
July 29th, 2009, 09:35 PM | #2 |
I use a small piece of wood that fits across the caliper piston and a large enough C-clamp to push brake caliper pistons back into the calipers on cars I work on.
July 29th, 2009, 09:38 PM | #3 |
Ninja fan
I have a piston compression too, but it's too big, and the rear brakes have 2 pistons, wich I can compress by hand. I just can't get the pad that the pistons ride on pushed back far enough to get the disc inbetween, although I havn't had a lot of time to work on it.
July 29th, 2009, 09:43 PM | #4 |
is the pregen rear brake pretty much like the new gens? if so, take a look at this post... does this help?
http://www.ninjette.org/forums/showp...7&postcount=32 |
July 30th, 2009, 06:31 PM | #5 |
Ninja fan
kindof, but the pistons on mine are smaller. I can't post pics right now, but the pistons aren't compressing any more than they are, and I just need like an 8th of an inch. It's really frustrating me right now.
Muzzy full exhaust, Dynojet kit stage 2, Asiancycle front flush mouts, rear pod turn signals, rear fender delete. Last futzed with by ians_04_250; July 30th, 2009 at 08:31 PM. |
July 31st, 2009, 03:33 PM | #6 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
Just use a large screwdriver, while the old pads are still in, to push the pistons all the way in. It helps to remove the res. cap and remove the fluid w/ a syringe or just put a rag around it to catch any fluid that might over flow from pushing the pads in. Then put in clean fluid and pump up. The flush or just leave it if its not too old of fluid.
August 2nd, 2009, 07:54 PM | #7 |
Ninja fan
got er all figured out. thanks for the help. Those pistons were stiff.
August 2nd, 2009, 10:34 PM | #8 |
make sure to flush the fluid.
Do you use your rear brakes and when? | ally99 | Riding Skills | 244 | May 22nd, 2013 01:57 PM |
when does a rear shock need replacing? | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 25th, 2013 08:38 PM |
Replacing Rear Tire Only? | AgentCircus | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 27th, 2010 02:27 PM |
Replacing rear rim for larger | Locksmiff | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 11th, 2010 01:55 PM |
Squealing Rear brakes | CrzyFstMnM | General Motorcycling Discussion | 2 | March 21st, 2009 05:40 PM |
