Old August 25th, 2010, 04:21 AM   #1
Ninja_Moose
Activating gate sensor problem
Do you guys know if there is a way to activate a gate sensor at an apartment complex with the Ninjette? Yesterday I was stuck at the gate waiting for a car to pull up behind me so that the gate would open .
Ninja_Moose is offline   Reply With Quote
Old August 25th, 2010, 06:28 AM   #2
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Maybe they can reduce the threshold needed to activiate it. I hate sitting at a red light and its stuck on red as it doesn't sense the bike. Then a car pulls up behind, but being a good bike sensitive driver, they stay like 10 feet behind so the light still doesn't trigger until, I pull up further and they pull up or I wave them up.
Old August 25th, 2010, 07:44 AM   #3
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Some complexes have garage door type remote that they can provide riders with. Check into it.
If they don't comply, a wireless angle grinder will eventually get you in....
Old August 25th, 2010, 07:50 AM   #4
maviam1
maviam1's Avatar
Motorcycle(s): 2009 ninja 250R
i had one of these when i lived in sparks, nv. the best i found was if you can see the lines cut into the pavement, try to make a tight turn over a couple of the lines. it worked for me. it just looks funny making a turn before leaving the gate. most of those type work on inductance, not on wieght. you have to be able to have enough mass over the rings to change the inductance and trip the sensor.
the man who smiles when things go wrong has thought of someone to blame it on.
maviam1 is offline   Reply With Quote
Old August 25th, 2010, 07:51 AM   #5
Cuongism
Cuongism's Avatar
The majority of sensors I've seen are inductive coils, not weight. In San Diego, almost very street light has them.
I have gates too and this is what works for me. Look at the ground near the entrance. You should be able to see a rectangle where they cut into the ground. The inductive loops are set off by metal (changes in magnetism). What works for me is having my wheel right on either end of the rectangle. Also, it helps if you're moving (the sensor senses changes in magnetism).
They also sell earth magnets you can attach to your bike that will trigger them better (never used one so not sure if they work). Motorcycles have a lot less metal than cars so it also depends on the sensitivity of the inductive loops. If you were never able to open the gate, I would ask them to raise the threshold.
http://m.wikihow.com/Trigger-Green-Traffic-Lights
Old August 25th, 2010, 08:06 AM   #6
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
Thanks for the tips and link.
My house is on a corner lot. There's no one driving on the side street on the weekends. I usually make a right turn then a u-turn.
tinng321 is offline   Reply With Quote
Old August 25th, 2010, 08:15 AM   #7
Cuongism
Cuongism's Avatar
I put my front wheel right on edges of the rectangle.
They're not all going to be rectangles as well though. The majority of them here are circles (advantage is it detects more than one car) and at corners they're diagonal rhombi. Hope this works for you. I always find the edges most sensitive.
Old August 25th, 2010, 08:42 AM   #8
In MSF class instructor mentioned some type of magnet to mount on the lower part of the frame that would set off the coil???
Old August 25th, 2010, 08:43 AM   #9
haha, or a ramp and Evel Knievel it.
Old August 25th, 2010, 08:45 AM   #10
Cuongism
Cuongism's Avatar
http://www.greenlightstuff.com/
It is also being sold at my local cycle gear (behind the counter though so you have to ask).
Old August 25th, 2010, 09:07 AM   #11
http://www.ninjette.org/forums/showthread.php?t=11414&
let us know if it works.
Old August 25th, 2010, 09:08 AM   #12
There have been threads here in the past saying that the magnets are useless, and don't provide nearly enough difference to affect the sensors. The tips here about where to place the front wheel and what areas to ride over seem more likely to have a direct impact. I haven't used the magnets, so can't comment on their efficacy myself.
EDIT: yup, kkim linked the first thread I was thinking about.
Old August 25th, 2010, 09:12 AM   #13
Rosie
Rosie's Avatar
Motorcycle(s): 2007 Blue Ninja 250R
That's pretty cheap too I'll have to stop by at Cycle gear and ask (I love shopping there!).
Rosie is offline   Reply With Quote
Old August 25th, 2010, 09:15 AM   #14
I've also heard putting the kickstand down on the sensor helps (haven't done that one, myself) or hitting the starter button to make the starter motor inductance help the detector "see" your bike.
Old August 25th, 2010, 09:22 AM   #15
Blackwidow
aren't apartment gate sensors different then the street light sensors?
Blackwidow is offline   Reply With Quote
Old August 25th, 2010, 09:24 AM   #16
But woudn't jumping the gate make one heck of an arrival and exit?
Old August 25th, 2010, 02:05 PM   #17
sixer
no joy
sixer's Avatar
Motorcycle(s): Ninja 2006 636
yeah the cycle gear red light tripper works- (gotta stay left on the sensor) But not for housing complex gates - atleast not for my buddy whos complex i visit...
I recomend the cycle gear one for the street- atleast fer cali.
sixer is offline   Reply With Quote
Old August 25th, 2010, 02:17 PM   #18
Cuongism
Cuongism's Avatar
Sorry, I actually don't use one. Once I figured out where to stop, I'm golden. To exit my complex, I don't need a remote, but to enter my complex I have to land correctly while pressing the button. I think there's some law where you shouldn't be required to need something to exit an area.
Old August 25th, 2010, 03:27 PM   #19
Rosie
Rosie's Avatar
That's interesting. I lived in a complex before that had a gated parking lot and in order to open/close the gates we had an actual transponder thingy to wave in front of the receiver placed by the gate... That was for in OR out.
Old August 25th, 2010, 04:45 PM   #20
tinng321
tinng321's Avatar
Tried this earlier. It didn't help. Waited, waited and waited till a car pull up. I didn't see any rectangle or circle, just patched up cracks.
Old August 25th, 2010, 06:35 PM   #21
Cuongism
Cuongism's Avatar
Yea, I never looked it up, but the explanation I was given made sense. If there was an emergency (most likely fire), people should be able to exit without our remotes in case we forget back in our apts (and can't run back in case of said fire).
I think the term they used was involuntary imprisonment. We're protected from people trying to get in, not people leaving. I used to use my remote to leave as well until other residents told me it was unnecessary. It can be that all our exits are gated including the pedestrian ones.
Old August 29th, 2010, 07:22 AM   #22
Ninja_Moose
Thanks for the tips guys. I located the sensors and there are two in front of the gate (to exit the complex). I tried rolling back and fourth on the sensors, placed my front wheels on the edges of the sensors, and turned off and started my Ninjette and still wouldn't open the gate.
I need to try weaving next time, hopefully I can find a way out without waiting for a car. I did see another bike leaving the complex through a side gate though, not quite sure how he activated the gate.
Old August 31st, 2010, 11:12 AM   #23
have you spoken to the apt housing manager about the problem?
Old August 31st, 2010, 02:07 PM   #24
Ninja_Moose
I haven't talked to the managers, but I did find a way to activate the gate. There are two sensors in front of the gate and I needed to cover the length of the sensor with the bike and it will open. Thanks for the help guys!
Old August 31st, 2010, 02:11 PM   #25
cool...
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
Golden Gate Bridge Ride anacron Videos 4 November 8th, 2013 02:06 AM
[crash.net - MotoGP] - Sensor problem for Simoncelli, season's best for Aoyama Ninjette Newsbot Motorcycling News 0 October 22nd, 2011 07:30 AM
Will gate spikes be a problem? Mr.E General Motorcycling Discussion 9 September 22nd, 2011 06:39 PM
[superbikeplanet.com] - Barbarians At The Gate: MotoGP At Jerez Is A Lock Ninjette Newsbot Motorcycling News 0 March 29th, 2011 10:20 AM
