Old April 22nd, 2018, 08:18 AM   #1
Tylorwashere
Motorcycle(s): 2005 Ninja 250
Replacing a valve stem
Does anyone have experience with this? Is it difficult to do on your own? Of course being Sunday no bike shops around me are open, and it just happens to be the nicest day of the year so far.
Tylorwashere is offline   Reply With Quote
Old April 22nd, 2018, 10:14 AM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
you talking the valve stem or the valve core? where is it leaking, or is it broke off?
Old April 22nd, 2018, 10:57 AM   #3
Tylorwashere
It broke off
Old April 22nd, 2018, 11:32 AM   #4
Z1R rider
Z1R rider's Avatar
you have to break the bead on at least one side of the tire-rim to get to the stem hole, then pull a new valve stem through from the inside, use dish soap for lube on the stem. carefully grab the valve stem below the threads with a pliers (or use a valve stem puller if you have one) until the stem is seated. Lube the bead of the tire with the soapy water and inflate, keep your fingers (and everything else) out of the bead!!
Old April 22nd, 2018, 11:58 AM   #5
Tylorwashere
Have ant tips on breaking the bead? I'm afraid of hurting my rim or tire
Old April 22nd, 2018, 01:06 PM   #6
Z1R rider
Z1R rider's Avatar
If your careful you may get it with a c-clamp, other than that you'd need to take the wheel off, lay it on the floor and lever the tire down till it pushes off the bead lock on the rim.
Old April 22nd, 2018, 01:32 PM   #7
I use large C-clamp to break bead. Use block of wood on fixed far side between clamp and wheel to not scratch it.
Rules require metal stems, so I just got a set of these. for my track bike and road bike. Never ever have to worry about cracked leaking valve stems again!!!
Old April 22nd, 2018, 03:09 PM   #8
Ram Jet
Ram Jet's Avatar
I like Drag Specialties valve stems. They thread in and are very sturdy.
Bill
Old April 22nd, 2018, 03:40 PM   #9
Tylorwashere
Thanks for all the tips guys, local kawi dealership does it for 10 bucks so I'll probably just take it to them tomorrow
Old April 23rd, 2018, 08:48 AM   #10
juanphatsun
juanphatsun's Avatar
Motorcycle(s): Ninja 250 2007
Since you're replacing the valve stem you should consider getting an angled valve stem for easier tire pressure checks and fill ups.
juanphatsun is offline   Reply With Quote
Old April 23rd, 2018, 03:26 PM   #11
Topaz
Topaz's Avatar
^^ +1
Much easier to access.
I got my 90 deg valve stems from Bike Master for two different bikes. They worked well. 11.3mm valves. Torque to 7 ft/lb.
Installing New valve stem FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 5 January 28th, 2015 04:22 PM
Angled valve stem randomwalk101 2008 - 2012 Ninja 250R Farkles 36 December 4th, 2014 09:38 AM
Valve Stem Size. N-m 1986 - 2007 Ninja 250R Tech Talk 12 May 6th, 2014 05:00 PM
Front Air Valve Stem kstrib 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2012 11:15 PM
Bad Valve Stem? gadgetguy1288 2008 - 2012 Ninja 250R Tech Talk 1 December 23rd, 2011 01:56 AM
