Old August 18th, 2018, 07:23 AM   #1
thumper64
Swapping EX500 cluster onto 250 bike.
I have a cluster from a 1996 ex500 I want to put on my 250 because reasons.
So the 500 cluster's lights work correctly, the oil, turn signals, high beam, and speedometer work after repinning the plugs. The tachometer doesn't seem to read correctly however. My idle was at about 900 on the 250 cluster. The 500 cluster shows it more like 400. Opening both clusters up, looking at the tach alone on both, they have the same IC chip and capacitors, just a couple different resistors and there's a trimmer I'm curious about if it may be able to be adjusted to calibrate the tach.
I adjusted the little blue trimmer on the circuit board and it made the gauge read closer to what it seems like it should, close enough for what I want it for.
Motorcycle noob, feel free to ignore me.
Last futzed with by thumper64; August 18th, 2018 at 03:15 PM.
thumper64 is offline   Reply With Quote
Old January 27th, 2019, 06:59 PM   #2
Still working as hoped?
Will an ex500 fuel tank fit on a 250? A.J. 1986 - 2007 Ninja 250R Tech Talk 4 June 4th, 2017 08:48 PM
EX500 Ignition Advancer works on 88-07 250's? fjyang 1986 - 2007 Ninja 250R Tech Talk 23 February 28th, 2016 03:43 AM
Bike swapping for a week kcaja1 General Motorcycling Discussion 11 September 13th, 2012 10:15 PM
lowering the bike question...but i have an EX500 spring rabies 1986 - 2007 Ninja 250R Tech Talk 5 September 8th, 2012 06:42 PM
