January 15th, 2019, 11:53 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2005 EX250, 2014 Royal Enfield Continental GT Posts: 87
No Headlight '04
I'm working on a 2004 that sat for a year. After installing a new battery I checked the electrics. The headlight worked. Now it doesn't work. In the fuse panel the headlight fuse connector, the lower plug goes to ground. The upper fuse junction doesn't connect. I checked with the ignition off and the ignition on.
Using a Power Probe the 3 wire switch reads grounds. I can apply a 12v to any of the wires. When I do, the headlight turns on. I can pull the Probe away and the the light stays on. When I turn off the ignition, then on again, I get nothing again. I do have a schematic from Cyclepedia. I don't know enough to figure this one out. Any suggestions? Bill |
January 15th, 2019, 01:26 PM | #2 |
Not sure if I understand but from the factory the ninja headlight does not come on until the bike is running. Hope that helps.
"It ended up being the loose nut behind the wheel" |
January 15th, 2019, 01:33 PM | #3 |
January 15th, 2019, 01:42 PM | #4 |
Yes but it is on a delayed circuit, guess the theory is to provide more power for cranking the motor. Is your bike currently running?
January 15th, 2019, 01:49 PM | #5 |
January 15th, 2019, 02:35 PM | #6 |
Then you are probably ok. It needs current from the stator to turn on the headlight initially.
January 15th, 2019, 02:38 PM | #7 |
January 15th, 2019, 03:28 PM | #8 |
Join Date: Oct 2016 Motorcycle(s): 95 ninja 250, 08 KLR 650 Posts: 68
I believe they're wondering whether the light turns on after the bike is running. After the bike is running if the kill switch is pressed the light will stay on, but if you turn the ignition off and then on again the bike will need to be started before the headlight will come back on. At least that's my limited understanding of it. Unsure if you can just touch the starter quick to turn the headlight circuit on.
January 15th, 2019, 05:57 PM | #9 |
Just so everyone knows, it is the law in the USA, that when the ignition is turned on, the headlight turns on. That isn’t a guess or a figuring.
If I had a second fuse box, I would put it in circuit to eliminate the possibility of a headlight relay gone bad. Speaking of the stator/starter combo, is anyone familiar with the wire that returns the circuit to the relay? |
January 15th, 2019, 06:11 PM | #10 |
yes, the light must be on when driving but...
it is off until after the engine fires.
January 15th, 2019, 06:29 PM | #11 |
The engine must be running.
My 2015 Honda Grom's headlight doesn't turn on until I fire the engine. Same with my 2006 Ducati. |
January 15th, 2019, 06:29 PM | #12 |
January 15th, 2019, 07:31 PM | #13 |
Guess I have to work on my communication skills.
January 15th, 2019, 07:45 PM | #14 |
January 15th, 2019, 09:47 PM | #15 |
January 16th, 2019, 07:09 AM | #16 |
My 2014 Royal Enfield turns on the headlight when the ignition is turned on. The wiring in the headlight has a jumper inline. It was added to comply with US import laws. RE makes the same bike for all markets, but modifies the wiring with the jumper for the US.
My 1994 BMW K75 is the same way. Obviously, if things are different, then things are different. Good news for me. I don’t want that headlight on until the motor is running anyway. Once the bike is in running condition and the weather isn’t too freezing and the tons of ice have melted, I may consider a MOSFET regulator/rectifier Roadstercycle.com. They work better at low RPM and they run cooler. The stock r/r is tech from the 1960s. |
January 16th, 2019, 09:36 AM | #17 | |
Cause and effect.
Very helpful for troubleshooting to not get them confused. Just because certain bikes are configured certain way (effect), does not mean there are laws that says so (cause): NO: bikes --> laws YES: laws --> bikes For example, you see 3 bikes going down freeway @ 80mph (effect), so can you assume that speed-limit law (cause) is 80mph? Nope. But assuming so can get you into trouble. Here's actual text from Code of Federal Regulations: Quote:
- it's on public roads - engine is running - rider is sitting on bike in approved fashion - bike is moving or about to move In which case, your headlight's behavior is perfectly normal and as-designed. It will turn on when you crank engine fast enough to activate headlight relay with power coming from stator-coils. |
January 16th, 2019, 09:52 AM | #18 |
Making assumptions on how circuits work also wastes lot of time on troubleshooting as well. Injecting external power into circuits is artificial and doesn't tell you anything about how those circuits work or are not working. Can also damage sensitive components in ECU. You'll want test by measuring and coming up with numbers at various parts of circuit to determine functionality.
By looking at wiring-diagram, we see that power from ignition-switch does not go to headlights. It goes to headlight-relay which is open/off. To determine what it takes to turn on headlight-relay, measure all junctions between battery and headlight-bulb: 1. measure voltage coming out of battery 2. measure voltage going into ignition-switch 3. measure voltage going out of ignition-switch with key ON (yours may be broken) 4. remove headlight-fuse and measure resistance between legs (if I had nickel every time fuse "looks ok") 5. measure voltage going into headlight-relay (this may be broken too) 6. measure resistance between ground of bulb-socket and chassis-ground 7. measure voltage going out of headlight-relay to bulb, then crank engine. Then it'll all make sense. You can't force circuit to work other than intended (other than re-wiring it). Measuring actual voltage allows you test wiring in between junctions as well. If you see voltage dropping unnecessarily between two junctions, there may be broken/corroded wiring or bad connectors. In this case, headlight-relay is turned on by stator-coils getting enough power from engine spinning (goes through diode to convert to DC to activate relay). Once relay is activated, its output-power going to headlights is looped back to its activation-coil to keep it on. So once it's on, engine-cranking is no longer needed to keep it activated. As others mentioned, headlight will stay on after engine stops spinning. |
January 16th, 2019, 11:10 AM | #19 |
"It will turn on when you crank engine fast enough to activate headlight relay with power coming from stator-coils."
Topic/headlight off? No one answered. Why all the off thread writing? You had no intention of offering help. A professional mechanic had my GT on his lift. I saw how he used the Power Probe to show exactly what was the problem in the circuitry. The Power Probe is most useful to someone with knowledge and experience. My knowledge and experience is limited on E250s. There is a thread in this topic. You criticize what you don’t understand and run off topic. Your unwanted analysis of the techniques in using the Power Probe III are off topic, not helpful, pedantic and self indulgent at my expense. Why not explain the circuit in the first place? All the off thread writing is your way of creating obfuscation, no more, no less. The Power Probe is very useful to someone with knowledge and experience. My knowledge and experience is limited on E250s. There is a thread in this topic. You criticize what you don’t understand and run off topic. Your unwanted analysis of the techniques in using the Power Probe III are off topic, not helpful, pedantic and self indulgent at my expense. If a need arises for an off topic, unhelpful, wannabe know it all, I assure you, I will specifically request your participation. Regards, Bill Gorry Last futzed with by Guaire; January 17th, 2019 at 08:46 AM. Reason: redundant text |
January 16th, 2019, 11:56 AM | #20 | |||||
Just because pro-mechanic can use Power Probe, doesn't mean that you can. An understanding of circuit from wiring-diagram is required first.
Last futzed with by DannoXYZ; January 16th, 2019 at 10:00 PM. |
January 24th, 2019, 08:08 PM | #21 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
Guaire,
Most everyone on this forum has a lot of experience with these pre-gens. Their advice is sage. We all do our best to help each other out.
... can't stop updating the bike! |
Aftermarket headlight or headlight conversion. | Caoboy | 1986 - 2007 Ninja 250R Farkles | 14 | February 28th, 2018 03:47 PM |
Anyone try this "headlight mesh" to 'reshape' their headlight? | iplante | 1986 - 2007 Ninja 250R Farkles | 9 | February 9th, 2013 07:06 PM |
Mounting stock headlight and gauges using headlight clamps? | SV_Hadder | 1986 - 2007 Ninja 250R Farkles | 0 | January 17th, 2011 09:15 PM |
