February 28th, 2011, 04:44 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA Posts: 753
Pod Filters
Ok, after spending a day and half removing and re-installing my carbs, yes you read that right a day and a half, I decided I would like to switch to pods. I didn't want to remove the back tire and re-installing them was a *****! One of the carb to airbox boots was harden and didn't want to go back on, even after being boiled.
I was thinking that if I switched to pods (1) it would be easier to remove the carbs if needed. (2) I could possibly create a small trunk with the new space. (3) The bike might gain another 0.10 hp . Seriously, I'm not looking for any gains, but that would be nice. The bike is completely stock and I'm not motivated enough to really change much. I have searched the forum and found quite a few answers, but I just wanted a 2nd, 3rd, and 4th opinion. So can I just add some pod filters without having to rejet? If so, which brand would allow for this? If I have to rejet, what combo (pod/jets) would be best for a stock 2000? Any and all help is appreciated. It's going to the shop this week for some other issues already. |
February 28th, 2011, 05:00 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
I have a pod filter and jets that came off a new gen. Not sure if it will fit on a pre gen though.
If you do install a pod filter, you will need to rejet. It is easy to work in the bike with the big air box removed!
February 28th, 2011, 05:00 PM | #3 |
You'll most likely have to re-jet. Changing from the stock airbox to pods leans the mixture out a lot more. I'm not sure what the jetting would be. I've got a new-gen and still have my airbox. You might be able to find some information on the jetting database.
February 28th, 2011, 06:01 PM | #4 |
‘94 Rider
Join Date: Nov 2010 Motorcycle(s): 1994 Kawasaki Ninja EX250F Posts: 81
You are making a good choice, in a few different ways. The biggest advantage for me is how easy it makes carb removal/installation. I can remove then reinstall my carbs in less than 5 minutes.
Also, they do make a slight difference in the upper-range of RPM. They also give the bike a louder, "bigger" sound. You WILL need to re-jet the carbs. If you don't your bike will likely run like sh*t, and over time, you will destroy your engine. In short, you will burn the exhaust valves and a bunch of other nasty stuff. You don't need to buy a jet kit, it's a waste of money. Depending on your elevation above sea level, my advice is to buy a pair of #108, #110, and #112 main jets. Try out each pair, and see which makes the bike run the best. Basically each jet size feeds the carbs a certain amount of fuel, which alters the air/fuel ratio. Also, buy a pack of #3 washers from the hardware store and shim the carb needles with one washer at a time until the bike runs like a champ. Hope this helps |
February 28th, 2011, 07:28 PM | #5 |
Thanks for the replies. The carb was already leaking fuel, so I swapped it out with another carb that I had. After the swap, no leaking fuel, but it was bogging down and would shut off. I was having the same problem with the old carb before it started leaking. I don't have much time to troubleshoot the issue now, which is why I was taking it to the shop. I figured if they are going to troubleshoot it, I may as well swap it out.
I have already checked out the Jetting Database and using the search feature, found that K&N Pods R-0990 seems to be the way to go. I wanted something small so that I could possibly have a storage area too. I do have a CycleGear and AutoZone near me, so I imagine I should be able to get everything there. So it sounds like pods, jets, and washers should to the trick. Anything else? Thanks. |
Pod filters worth it? | Lllewis87 | 1986 - 2007 Ninja 250R Tech Talk | 24 | May 19th, 2014 07:47 AM |
Those with pod filters | Dark | 2013 - 2017 Ninja 300 Tech Talk | 9 | July 26th, 2013 08:03 PM |
just installed pod filters | lolibater | General Motorcycling Discussion | 42 | January 19th, 2013 11:00 PM |
chrome pod filters | snowsoldier | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 16th, 2011 09:21 PM |
Pod Filters and Jetting Question | virtualmatt | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 3rd, 2010 09:50 PM |
