Go Back   ninjette.org > General > Off-Topic
Old June 10th, 2013, 06:05 PM   #1
BMW tries cliff jumping...
... and fails painfully.
Old June 10th, 2013, 06:54 PM   #2
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Woah...
Amazing how today's camera are indestructible... Can't say the same thing for today's car...
Cliff:1 Innocent driver:0
broken neck is offline   Reply With Quote
Old June 10th, 2013, 07:32 PM   #3
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
such a waste of a great car.....
Live2ride is offline   Reply With Quote
Old June 10th, 2013, 07:37 PM   #4
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
I hate Dbags that drive like this on public roads. What if you were coming around that turn on your bike? that's the type of things I think about when I see people driving like this. Is it wrong of me to say, good, he deserved that? well i hope he's ok and learned a lesson.
I do have to say i've never seen that camera angle before and quite like it.
az3200 is offline   Reply With Quote
Old June 10th, 2013, 07:51 PM   #5
Aurodox
Motorcycle(s): -
Understeer...all he needed to do was brake.
Aurodox is offline   Reply With Quote
Old June 10th, 2013, 09:30 PM   #6
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Lol that's not how that works.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old June 10th, 2013, 09:56 PM   #7
Aurodox
Motorcycle(s): -
Oh? 100% of the time my car has under steered, slowing down has fixed the problem.
Old June 10th, 2013, 11:05 PM   #8
CycleCam303
King Hamfist
CycleCam303's Avatar
Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796
Yeesh, scary. I've driven cars like we ride our bikes. I've seen some solid mistakes and learned a few things about canyon driving. Aside from the obvious bad things about crossing the double yellow and using the whole road, the driver showed a not so obvious flaw. Using the whole road means you can go a lot faster than just using the right lane. In turn you give yourself no run off room for errors. He botched that corner royally to begin with but if he was focused on staying in his lane the lower speed could have prevented the front from walking off the road. What sucks about under steer is you can't do much but let off the gas. It'll take the front tires a few feet to regain grip though. The problem was he just over cooked the corner and was totally screwed.
Although he maybe, a big maybe, could've saved it with some left foot braking. Stock e46 m3s have a staggered tire set up along with a large front sway bar. Smaller width tires up front with wide meat in the rear. This promotes under steer at the traction limits. In front wheel drive and 4 wheel drive cars which naturally under steer using a little braking while staying neutral on the gas will kill under steer and can even get the car to rotate. This usually causes snap oversteer in rear wheel drive cars but the m3 has quite a bit of under steer tuned into it so it might have gotten the car to bite.
CycleCam303 is offline   Reply With Quote
Old June 10th, 2013, 11:11 PM   #9
CycleCam303
King Hamfist
Before this turns into a debate, when under steering is happening get off the gas and apply correctional steering inputs. The front tires are over loaded and can't provide more traction. Getting on the brakes overloads the tires even more. What I said about left foot braking is a technique that uses weight transfer to get the front to grip more.
Old June 10th, 2013, 11:17 PM   #10
Aurodox
Motorcycle(s): -
Yeah I meant light braking purely to get more weight on the front. Not slamming on the brakes. I'm no expert which is why I stick to the speed limit.
Though I used to feel the need to show off to my buddies and my car understeers like none other. The crappy thing with understeering is the car doesn't turn as sharp as you like, so the natural response is to turn the wheel more which just makes it worse. At least that's been my experience.
Old June 10th, 2013, 11:31 PM   #11
CycleCam303
King Hamfist
Yup sounds like you already know a little bit. On road courses the common noob mistake is to use too much steering input. If @rojoracing53 would post his video of him and his dad driving a 370z at Laguna seca you can see that he uses a lot of steering and the front tires are howling. His dad drives with an open circuit style that doesn't stress the tires as much by using weight transfer and minimal steering. That's not to say rojo's style is wrong. It's more of an autocross/short course ideal way of driving.
I have no idea what you drive but I'll assume its a front driver. Better tires work wonders, best upgrade period, but big ass rear bars are a front drivers best friend. Unless its a crx, ee/ef civic hatch or a scion tc. Those cars rotate pretty well. I kid you not the tc shocked me when the rear end actually came around.
Old June 11th, 2013, 05:53 AM   #12
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
That'll buff right out, at least his blinkers are still working
Old June 11th, 2013, 06:04 AM   #13
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Fine ill work on the 370 videos this week and for your information if your tires aren't making noise or leaving black stripes your not having fun and this is true for both bikes and cars
Old June 11th, 2013, 09:17 AM   #14
CycleCam303
King Hamfist
Anyone can hang out the front lol. Look what happened when you hung out the rear
Old June 12th, 2013, 06:16 AM   #15
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Proof that squids also drive cars.
Old June 14th, 2013, 08:52 AM   #16
lgk
The curve looked like a decreasing radius spiral.
The only way he could have made the turn successfully at speed is if he slowed down more at the beginning and applied more throttle in the middle of the curve to oversteer.
Im hoping these guys had spotters, at the beginning and end of their route. Otherwise it would be extremely dangerous.
[motorcycle.com] - Ride Over Your Head, Fall Off A 40-Foot Cliff + Video Ninjette Newsbot Motorcycling News 0 April 4th, 2014 05:00 PM
[hell for leather] - Fiscal Cliff bill extends electric motorcycle tax credit Ninjette Newsbot Motorcycling News 0 January 2nd, 2013 05:00 PM
[hell for leather] - Watch a dirt bike fall off a cliff Ninjette Newsbot Motorcycling News 0 July 8th, 2011 12:10 PM
[topix.net] - Motorcyclist Found Dead After Sonoma County Cliff Plunge Ninjette Newsbot Motorcycling News 0 January 5th, 2011 07:20 PM
[roadracingworld.com] - R.I.P. Land Speed Record Holder Cliff Gullett Ninjette Newsbot Motorcycling News 0 September 4th, 2008 09:23 AM
