Old April 12th, 2015, 10:41 PM   #1
MrAtom
MOTM - July '15
Bike is running lean
a while back, I replaced my air filter and I noticed the bike started performing better, but I think it's also running lean because it doesn't immediately return to idle. The RPMs hang for a second. Now, I know it's bad to run lean because the full potential of the bike is not there. but, it's also bad because it causes the bike to get really hot, and it can damage stuff. My bike doesn't seem to be getting too hot according to the thermometer. I'm going to rejet the carbs and shim the needles, but should I be in a hurry to rejet the carbs?
Old April 13th, 2015, 07:09 AM   #2
ieathonda
ieathonda's Avatar
Motorcycle(s): Ninja EX250F
Is it just an OEM replacement filter? Most stock bikes tend to do well with a shim or two under the needle. Rejetting may not be needed depending on if you have any other modifications (ie, full exhaust). With my stock bike i did end up running two shims because the midrange was rather "sloppy" in my opinion and that helped to get a little more fuel into the bike at certain rpm's.
refer to this link:
http://faq.ninja250.org/wiki/Washers_for_carb_needles
and this one: http://faq.ninja250.org/wiki/Why_wou..._my_jetting%3F
ieathonda is offline   Reply With Quote
Old April 13th, 2015, 07:24 AM   #3
Ghostt
Ghostt's Avatar
Agreed @ieathonda do the shims first.
violente et ignorantia
ZX-2R BLOG
Old April 13th, 2015, 03:08 PM   #4
MrAtom
MOTM - July '15
Yeah its just the stock filter. Ill shim it and report back!
Old April 13th, 2015, 03:53 PM   #5
Ghostt
Ghostt's Avatar
Also don't forget to tune the idle mixture screws.
Your initial setting should be 3 full turns out from the bottom, remember just slightly tighten them, don't go all Conan on them.
Then warm it up, slowly turn 1 side pilot screw in until the rpms drop, then back out till RPM's peak (and no further)* Twist throttle...see how it reacts...tweak to taste.
Repeat on other side... test ride. You're looking for best throttle response and transition from just cracked to 1/4 throttle opening or so.*
Thats a quickie, 10 cent tutorial on setting pilot screws.**
ZX-2R BLOG
Weird problem, bike running too rich and lean... bjl4776 2008 - 2012 Ninja 250R Tech Talk 22 May 29th, 2014 04:25 PM
Bike Running to Lean, How Long Do I Have? WayToFast 2008 - 2012 Ninja 250R Tech Talk 6 March 23rd, 2014 05:31 AM
Bike running lean out of the blue. agentbad 1986 - 2007 Ninja 250R Tech Talk 6 January 20th, 2014 03:10 PM
bike running lean, hard starting d16soda 1986 - 2007 Ninja 250R Tech Talk 19 October 25th, 2011 09:25 AM
Am i running lean? OGjackafidy 2008 - 2012 Ninja 250R Tech Talk 8 September 19th, 2011 07:06 PM
