Old August 25th, 2008, 10:53 AM   #1
JCCJMM_
JCCJMM_'s Avatar
Motorcycle(s): 2007 EX250
Oil change question
Disclaimer: I am a nervous nelly about my maintenance....has to be dang near perfect.
Changed the oil yesterday. All went well. But I was wondering......is it normal for a little oil to seep past the plate's gasket until it has a good seal?
I always under tighten bolts as a habit. After my morning commute, I noticed a tiny bit of oil seeping (not dripping) around the plate.
Seems like the same thing happened last time I did an oil change, but the oil stopped seeping after a few rides.
BTW... I am not a big believer in torque wrenches. I have worked on my own cars for over 20 years (all maintenance except rebuilds and welding) and learrned the art of "feeling it" with wrenches.
JCCJMM_ is offline   Reply With Quote
Old August 25th, 2008, 01:40 PM   #2
Did you use a new gasket? If not, may be worth picking one up. The folks at another ninja forum are pretty anal about torquing that bolt to exactly 14.5 ft/lbs because it's pretty easy to overtighten it. But if you're sure you didn't overtighten it, and you did use a new gasket, then I'd just monitor it for the next few days to see if there is any continued leak or if it was just in the beginning.
Old August 25th, 2008, 04:32 PM   #3
JCCJMM_
JCCJMM_'s Avatar
The Fram filters that I use include both new gaskets with the filter.
I also coated the gaskets with oil to help seal. If anything, it may be too loose. It is not even close to as tight as it was when Kawasaki put it on. I had to break a little sweat to get it off the first time!
Old August 26th, 2008, 09:31 AM   #4
JCCJMM_
JCCJMM_'s Avatar
I tightened the thing up a smidge more and am good to go.
Obviously I overthink things at times.
Old December 4th, 2008, 05:38 PM   #5
Sailariel
Sailariel's Avatar
It will feel very tight when you unscrew the filter initially. The reason is that the engine is hot. I generally let the oil drain overnight, replace the filter and o ring (make sure the o ring is wet with oil,) and torque to 14.5 foot pounds. I change oil every 2500mi.
Oil change question Mbomb 2008 - 2012 Ninja 250R Tech Talk 5 September 8th, 2012 12:08 AM
oil change - question! vmlp 1986 - 2007 Ninja 250R Tech Talk 5 June 5th, 2012 08:04 PM
oil change question ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 8 April 19th, 2012 06:46 PM
Oil change question. Will this work? kaiserz 2008 - 2012 Ninja 250R Tech Talk 3 May 2nd, 2011 06:45 PM
I did my 1st oil change question! Duvivr6 2008 - 2012 Ninja 250R Tech Talk 19 July 7th, 2009 08:19 AM
