Old March 8th, 2011, 08:21 AM   #1
4x4kayak2112
Motorcycle(s): ninja 250
snorkel removal
i have a stock 06, can i take out the snorkel without shimming?
ive search for the pre gens but nothing comes up
4x4kayak2112 is offline   Reply With Quote
Old March 8th, 2011, 08:37 AM   #2
dubojr1
dubojr1's Avatar
Shimming will be necessary. Removing the snorkel will allow more air in on the bottom range of RPM's. Generally our bikes are already lean there and removing the snorkel will only intensify the effect.
I believe it is agreed that anyone who has shimmed has loved the results. I highly recommend it.
Old March 8th, 2011, 08:49 AM   #3
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
X2
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old March 8th, 2011, 11:09 AM   #4
Jinx250
Smoker
Motorcycle(s): Guess....
Now if only the 06 had snorkels...
Jinx250 is offline   Reply With Quote
Old March 8th, 2011, 11:17 AM   #5
dubojr1
dubojr1's Avatar
Wouldn't the "intake cap" be the same thing...
Old March 8th, 2011, 11:21 AM   #6
yes it would, but I believe you will need to do some work to keep the filter in place as that cap helps to position the filter in the pregen's airbox... is that correct jinx?
Old March 8th, 2011, 11:29 AM   #7
dubojr1
dubojr1's Avatar
Yeah, kinda looks that way.
Old March 8th, 2011, 11:40 AM   #8
4x4kayak2112
yes all you use is wire coat hanger.
Old March 8th, 2011, 11:44 AM   #9
cool... how about taking some pics for a DIY when you do it?
shimming will make the bike easier to ride w/o the snorkel as removing it leans out the bike even more.
Old March 8th, 2011, 12:16 PM   #10
dubojr1
dubojr1's Avatar
Is there another option? Won't the coat hanger rust away?
Old March 8th, 2011, 05:08 PM   #11
HKr1
IC2(SW)
HKr1's Avatar
Top intakes by the tank are kinda cool looking..... But I didnt know the intake to the carbs were so restricted.
http://cgi.ebay.com/ebaymotors/2006-...Q5fAccessories
Old March 8th, 2011, 06:23 PM   #12
Couldn't you just cut the two tubes on the airbox lid flush with the rest of the top? the tubes create restriction because the air has to be sucked thru and forced into the tube... i think... so if you took length off the tube, you could have the same size hole with less restriction and more flow. Right?
I've been thinking about doing this for a while, but idk how much more air my system can handle without rejetting, and if I rejet, I might as well just do pods, as they're tons easier to remove the carbs and lighter as well.
Old March 8th, 2011, 06:23 PM   #13
4x4kayak2112
mine in my 05 never rusted when i put my muzzy/jet kit/snorkle removal. i put 15k on that bike...never was a issue. i guess the frame would rust too?
i ended up going to pods after the 15k, never looked back (sold the bike with 22k miles on it.)
Old March 9th, 2011, 09:40 AM   #14
Jinx250
Smoker
Why not just go with a K&N Drop in filter?
Old March 9th, 2011, 04:28 PM   #15
From what I can tell, the K&N drop-in filter flows more by letting in more dirt.
http://faq.ninja250.org/wiki/Which_a...e_Ninja_250%3F
Snorkel Removal Driddle 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2013 07:51 PM
Snorkel removal questions NHrider19 2008 - 2012 Ninja 250R Tech Talk 11 June 6th, 2012 09:05 AM
Snorkel Removal on EFI Ninja 250R? hackeron 2008 - 2012 Ninja 250R Tech Talk 16 February 2nd, 2012 10:43 AM
Quick Question About Snorkel Removal LegB4Wicket 2008 - 2012 Ninja 250R Tech Talk 8 December 11th, 2010 10:49 AM
inconsistent throttle/rpm after shimming and snorkel removal Hokie11 2008 - 2012 Ninja 250R Tech Talk 3 July 23rd, 2009 03:17 PM
