September 19th, 2011, 02:28 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): Red 2009 Ninja 250r Posts: 132
Am i running lean?
So i put just the square kandn high flow air filter on and it seems to run at 1000 rpms at idle cold and then up to 1100 or 1200 warm which seems a little bit lower than usual. is it running lean and for the filter to function properly do i need to rejet?
"The goal in life is to die young at a very old age" " Four wheels moves the body, two wheels moves the soul' |
September 19th, 2011, 02:51 PM | #2 |
shim or rejet. you're letting more air in so you leaned it out
http://sandollarmotorcycleclub.com/ |
September 19th, 2011, 02:53 PM | #3 |
Just changing the filter would not require rejet or shim the carbs.
Hell on my bike I only changed the air filter (pipercross) and my exhaust smelled rich, (been told these bikes run rich from stock) so I removed the snorkel... been told to shim the carbs doing this method (air filter & remove snorkel) but I haven't done that yet and mine seems to run just fine and the exhaust doesn't smell as much like gas. Plus I haven't noticed anything on the rich vs lean type threads happening on my bike, so not soo sure it's 'mandatory' to shim the carbs. |
September 19th, 2011, 03:04 PM | #4 |
As the outside temp changes you may need to adjust the idle slightly. Cooler outside temps may make it idle a little lower.
September 19th, 2011, 04:21 PM | #5 |
that could be. im planning on ordering a dynojet stage 2 friday when i get my paycheck so hopefully it will all work out. is it a must to remove the snorkel when you rejet?
September 19th, 2011, 04:51 PM | #6 | |
You can check the jetting database to see what others have done. Having your bike Dyno Tuned wil help you get the most out of rejetting your bike. http://www.ninjette.org/forums/showt...tting+database http://www.ninjette.org/forums/showthread.php?t=10208 |
September 19th, 2011, 05:23 PM | #7 |
Motorcycle repair
Join Date: Sep 2011 Motorcycle(s): '05 Ninja ZX6-RR, '08 GY6 scooter for wife, '02 Shadow ACE, '05 Buell Blast Posts: 28
Running lean will NOT make it idle lower. A high idle, taking awhile to idle down, or in extreme cases, won't stay running are symptoms of a lean condition.
Also these bikes, like every modern day bike run lean from the factory due to emissions laws and manufacturers desire to make the bikes pass the smog test. I have yet to meet a bike that didn't love me after a rejet or in FI models a PCIII. My advice is check idle, plugs, and rejet just so your bike will run like it should've when it rolled off the assembly line
"You can't know where you're going until you know where you've been" www.monkeywrenchmotorcycles.com |
September 19th, 2011, 05:43 PM | #8 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
dont you want a bigger bike in a couple months?
blink-182 |
September 19th, 2011, 07:06 PM | #9 |
I do want one but my hours got cut at work so for the time being im gonna stick with the 250 and see what next summer brings and either way im not selling the ninja so i may as well work on some mods
Running Lean or Rich? need help | mkulchar | 2008 - 2012 Ninja 250R Tech Talk | 105 | October 3rd, 2021 01:13 PM |
Bike is running lean | MrAtom | 1986 - 2007 Ninja 250R Tech Talk | 4 | April 13th, 2015 03:53 PM |
Bike running lean out of the blue. | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 6 | January 20th, 2014 03:10 PM |
Running lean after valve adjustment? | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 22nd, 2012 05:59 PM |
Running Lean? | Kristofferzero | 2008 - 2012 Ninja 250R Tech Talk | 14 | April 20th, 2012 10:06 PM |
