Old March 5th, 2012, 08:22 PM   #1
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Motorcycle(s): 2010 Green Ninja 250 SE
Weird Cold Starting Idle
So when I warm up my bike in neutral, I apply a little choke to assist in the warming up of the bike. However, when I crank the bars to the left, the RPMs increase about 1000. If I straighten the bars, the idle goes back down 1000RPM. When I do it to the right, the RPMs stay constant and no change happens.
I dont know why the RPMs would increase when I crank the bars to the left. Any ideas?
ajcadoo is offline   Reply With Quote
Old March 5th, 2012, 08:33 PM   #2
Turning the bars is tugging either the throttle cable or the choke cable. Neither are a good thing, but the choke cable probably wouldn't matter as much compared to a misrouted throttle. Readjust them both until you can move the bars at full lock in either direction without the idle changing at all.
Old March 5th, 2012, 08:34 PM   #3
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
lol...I have the EXACT same condition. I have made a mental note to check the choke cable for any slack/deformity, the next time I removed the tank, which should be this week (shimming). It doesn't bother me that much though.
On a related note though...I thought I had convinced you to NOT warmup the engine @ idle, me very disappointed in you boy
EthioKnight is offline   Reply With Quote
Old March 5th, 2012, 08:37 PM   #4
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Ok sweet, I will definitely check it out. I didnt know if maybe my fuel line was getting pinched or something weird.
haha, I dont remember anyone saying that but I have read that idling in neutral with the choke for a minute or two is good to get the oil flowing throughout the entire engine. I have been doing this for only cold starts. What is the reason for not doing this?
Old March 5th, 2012, 08:40 PM   #5
EthioKnight
Super Noob
Here you go bud...
http://faq.ninja250.org/wiki/Warming_up_your_engine
Just feels like Dejavu...maybe it wasn't you that I advised after all, my apologies
Old March 5th, 2012, 08:43 PM   #6
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Here you go bud...
Using the choke puts the engine under a load right? The main point of that answer is that the bike warms up when the engine is under load. I warm it up with the choke engaged for a minute and then drive off. I do not idle (without choke) to warm up the bike.
Old March 5th, 2012, 08:57 PM   #7
EthioKnight
Super Noob
No, you'd have to be moving for the engine to be under load. The choke just enrichens the mixture (gas/air) in the carbs for easy starting during cold temps.
Old March 5th, 2012, 08:59 PM   #8
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
kk sweet, thanks for the info! I will be definitely doing this from now on.
Old March 5th, 2012, 09:02 PM   #9
EthioKnight
Super Noob
Old March 6th, 2012, 08:54 AM   #10
gilmorec61
gilmorec61's Avatar
Same thing happened to mine but it was when i turned it all the way right. When i got around to shimming my needles and stripped her naked, i located the problem, and just rerouted the cables so i could completly turn the wheel both ways without it doing what you said. No biggie!
gilmorec61 is offline   Reply With Quote
Weird Cold Start Noise Joshorilla 2008 - 2012 Ninja 250R Tech Talk 2 October 14th, 2012 02:07 PM
weird starting problem dbking321 1986 - 2007 Ninja 250R Tech Talk 10 April 19th, 2012 04:12 AM
Really low idle speed when starting??? HELP!! Ktaylor07 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:57 PM
Idle weird Rafalski 2008 - 2012 Ninja 250R Tech Talk 17 August 28th, 2009 09:56 AM
Cold Weather Idle? Flashmonkey 1986 - 2007 Ninja 250R Tech Talk 26 April 19th, 2009 04:35 PM
