June 11th, 2010, 11:22 AM | #1 |
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250r SE, 2007 Daytona 675 Posts: 95
Engine Oil Gauge
I purchased a brand new 250r SE earlier this week from a dealership. And after putting nearly 20 miles on it. I have run into some problems with the bike shutting off when trying to get out of first, and I am not stalling the bike. The engine just sputters and then dies. I am also giving it full throttle and it still just sputters. This has happened on about 2-4 occasions already. But I do not run into any problems if I have the choke cracked open a little. I have not done any mods what so ever to the bike since I received it.
I cannot figure out what the problem is, but when I looked at my engine oil gauge, I can see completely through it, but I see a little bit of oil at the bottom. Anyone have any ideas what may be the cause of the problems? And also can anyone do me a big favor a take a picture of their engine oil gauge, so I can see how it should look with oil it in. |
June 11th, 2010, 11:31 AM | #2 |
Look at the last pic in the DIY Oil change thread:
http://www.ninjette.org/forums/showthread.php?t=10780 and there is a pic of what the oil level should look like. The bike needs to be straight up and down and on a level surface to be reasonably accurate, can't be leaning over on the sidestand.
June 11th, 2010, 11:35 AM | #3 |
if your oil level checks out good, how long are you warming up the bike before starting off to ride?
June 11th, 2010, 11:42 AM | #4 |
This one is not from our bikes but the principal is the same....
June 11th, 2010, 11:45 AM | #5 |
I just looked at my oil gauge and it appears to be completely empty. I currently have the bike on both front and rear stands.
I am warming up the bike for roughly 5-10 minutes. And I had the same problem after going on a 10-15 minute ride to a buddy's house to pick something up. And I had the bike running while I was at his house too which was about 5 minutes or so. I am starting to think that I got screwed over by the dealership, and they did not properly prep the bike the way they should have before they delivered it to me. But would the lack of engine oil cause my bike to sputter and die out? |
June 11th, 2010, 11:51 AM | #6 |
is the choke all the way off after you warm up the bike?
yes, you should see oil in the window when the bike is vertical. Try seeing if oil appears in the window when the bike is vertical without stands, with the tires on the ground. If not, keep pulling the bike over towards the right side and see if oil starts to appear in the window. That way, if it does, you'll know you're only down by a little but instead of not having any oil at all. Could it be that the oil is so clean it appears like there is nothing in the window? |
June 11th, 2010, 11:55 AM | #7 |
I either turn the choke off after warming up the bike or else I open it up a little and shut it off after a block or two.
As for the oil being so clean. I opened up the oil cap to look inside but didn't seen and kind of liquid in there. I can only see oil inside if I tilt the bike to the far right side. But if it is on the kickstand, and in the upright position I still do not see any oil. |
June 11th, 2010, 11:58 AM | #8 |
You might want to call your dealer at this point (ask to speak to the service or sales manager) and see what they say. Further futzing around by you at this point may give them cause to try and blame you for a lack of oil, if it is indeed the case. The oil is filled at the factory and I highly doubt the dealer checks that as part of their pre sales inspection, though they should.
June 11th, 2010, 12:04 PM | #9 |
Ahh, If the bike is standing upright and I don't see any oil, do you think I should try adding a little bit more oil?
Would the oil make a big enough difference to make the bike sputter? Because the oil is really just to keep all the internals of the bike lubricated. So could there be something else that is causing the problem? |
June 11th, 2010, 12:22 PM | #10 |
first things first... call the dealer and let them know what you are experiencing. At that point if they tell you to add oil, then add oil.
If your bike has NO oil, for some reason, there is a possibility of engine damage at this point. Filling the oil now, by you, would give the dealer cause to say that there was oil in there to begin with it was you who caused the problem, somehow, and try not to cover it under warranty. Get the dealer involved at this point just in case there is warranty work due to no oil in the crankcase. |
June 11th, 2010, 12:38 PM | #11 |
Thanks for all the advice from everyone. I will definitely call the dealership and see whats up. And see if I can get them to check it out.
June 11th, 2010, 12:41 PM | #12 |
last thing you want is to ride the bike there is it has no oil. just talk with them, see what they recommend and let us know what they say before you do anything. They may say to just fill it up w/ oil, but you want them to be the ones to tell you that to cover yourself for warranty work, if needed. Like I said, be sure to discuss this with the sales or service manager.
June 11th, 2010, 02:29 PM | #13 |
Just an update. I called my dealership but then found out that the sales manager that sold me the bike was actually off today, so I spoke with someone from the service department. But the guy that I spoke with said that they have a separate department that deals with brand new bikes before they go out.
Anyways, the guy that I spoke with said that it was unusual for there to be a lack of oil showing up in the gauge, and told me to double check everything on the owner's manual and to get a hold of my sales rep and have them come pick up the bike so that they can check it out. Thanks again for everyones help and advice. |
June 11th, 2010, 03:50 PM | #14 |
Let us know what happens.
June 12th, 2010, 01:37 PM | #15 |
Update: I got the dealership to come and pick the bike up so that they can take it back for inspection. Still have no idea what the problem was.
But I will update again when I hear back from the dealership. |
Engine Oil | Mrudloff | 1986 - 2007 Ninja 250R Tech Talk | 24 | March 23rd, 2015 08:59 AM |
White Marks in Oil Level Gauge | dnovosel | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 8th, 2013 07:36 AM |
Where Did My Engine Oil Go? | Francis | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 1st, 2011 10:15 PM |
Oil level glass gauge/Frame bracket for exhaust hanger questions | MKlein3004 | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 26th, 2011 11:25 AM |
I Dropped my feeler gauge down into the Engine!!!!!! | TheAmazingKickstand | 1986 - 2007 Ninja 250R Tech Talk | 18 | August 7th, 2009 04:04 PM |
