March 25th, 2022, 11:16 AM | #41 |
Join Date: Mar 2022 Motorcycle(s): kawasaki ninja 2007 250f Posts: 1
Great info
Thank you for the info. Was searching for hours for any info on anything realted to 250 pre gen fairings
March 25th, 2022, 01:49 PM | #42 |
Yah I've had real good luck so far with just crazy glue ! it worked for me !
i got a large bottle of the crazy glue gel from my local hardware store , and used that.... so far it's held just fine .... I have not tackled the big cardboard box of fairing pieces that I bought with it though... some of them are really tore up... and will need extra sheets of the ABS to patch it.... I'll get the sheets of ABS from Mc Master/Carr supply ....with my heat gun I should be able to heat up the sheet and lay it on a good fairing to get the shape of the busted one, then cut out the piece and glue it in there........at least that is the plan. ( I'll lay waxed paper between the good fairing and the hot piece so it won't stick to it) .... Bob....
March 26th, 2022, 12:45 PM | #43 |
Join Date: Oct 2020 Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250 Posts: 233
