Old February 2nd, 2022, 02:50 PM   #1
bigBug
Choke not working properly
So my bike is running very stable. Starts up every time and everything is fine, but just my choke doesn't work that well. I always have to turn the idle screw 4 full turns with the choke on just for it to be able to idle at 2000rpm. I could run on choke without turning up the idle but it is idling at 700 rpm stuttering. Once it gets a little warm the bike idles very well. It started right after I cleaned the carburetor last time.
What do you guys think could be the cause of the problem?
bigBug is offline   Reply With Quote
Old February 2nd, 2022, 03:01 PM   #2
Hi, are you pulling choke lever all way back to max until it stops?
is your choke cable positioned properly at carbs?
Should have ferrule fully seated in lever with cable-end seated in stop.
Cable should pull on lever about 10mm when you pull on lever fully.
Old February 2nd, 2022, 03:16 PM   #3
And are the valves known to be in spec?
Old February 2nd, 2022, 03:58 PM   #4
ducatiman
ducatiman's Avatar
clean both choke pickups using guitar string (small red circle in photo)
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old February 2nd, 2022, 04:07 PM   #5
bigBug
I think I hooked it like that but I'll double-check.
Valves are in spec
ducatiman: I dipped it in solution. Do you think it wouldn't have cleaned it out?
Old February 2nd, 2022, 04:16 PM   #6
ducatiman
ducatiman's Avatar
not necessarily...a very long fixed "jet", they can clog up pretty good, takes a good poke with guitar string to fully clear them.
Custom Carb Service
Old February 2nd, 2022, 07:29 PM   #7
One recent case had choke-jets so plugged up with dried petrol, even guitar wire couldn't clear. Had to drill out with micro-bit!
Old February 16th, 2022, 06:03 AM   #8
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
Ducattiman is the man with the answers ! ...so that is how you get around those corners...Guitar strings !..... "ingenious"
...better than my flattened coil spring !
Bob.......
Old March 24th, 2022, 08:52 PM   #9
bigBug
Ducatiman is really the superman around this site. It was that little choke hole, cleaned it out with a copper wire and choke cleaner. it worked. Finally got both good idle and choke running at the same time.
**choke problem is solved**
Two more problems though.
1. When I opened it though there was a lot of white rubber like residue on the butterfly valves, how could prevent that from happening?
2. I have another problem though a non starting issue. My gas tank had to be welded from the petcock side because the factory nut inside cracked. Long story short after tapping those holes they are weren't perfect straight and the tap screw wasn't as perfect as the factory holes. Now I put a Nitrile rubber gasket in between the bolt and nut but the rubber keeps deteriorating from gas. Do you guys know a rubber like material that won't deteriorate from gas?
I'll make another thread for this
Thanks everyone!!
Bike dies with choke after not storing properly... seamuswh 2008 - 2012 Ninja 250R Tech Talk 2 May 15th, 2012 10:47 PM
cluster not working properly after rain Oaklandish 1986 - 2007 Ninja 250R Tech Talk 6 October 8th, 2011 07:21 AM
Choke not working r311music 2008 - 2012 Ninja 250R Tech Talk 10 August 25th, 2011 07:05 PM
Left turn signals not working properly maraci 2008 - 2012 Ninja 250R Tech Talk 7 April 16th, 2011 07:38 PM
LED brake/tail lights not working properly... sktrs_kpr 1986 - 2007 Ninja 250R Farkles 1 April 8th, 2010 09:59 AM
