March 4th, 2022, 11:37 PM | #1 |
Join Date: Feb 2022 Motorcycle(s): GPX250R 2006 Posts: 23
My front sprocket seemed to have had rubber dampers?
While I was fixing my neutral wire, I noticed that the sprocket does not look like in the wiki. At the bottom just left of the bolt is a piece of green rubbery stuff. It looks like there should be 6 but there is only one left. I found what I thought were other ones in the crud in the cover. What is this - I suspect some sort of chain damper? Will their lack be a problem? Cheers.
March 7th, 2022, 09:33 AM | #2 | |
Join Date: Sep 2021 Motorcycle(s): 07 Kawasaki Ninja 250 Posts: 343
March 12th, 2022, 02:34 AM | #3 |
OK thanks. I am planning a chain and sprockets change in the future and will fix it then.
96 250R Sprocket cover & rubber feet | nickcasa | 1986 - 2007 Ninja 250R Tech Talk | 7 | January 25th, 2014 11:32 AM |
Rubber build up on front fender | MarcoPolo | General Motorcycling Discussion | 6 | May 10th, 2012 09:16 PM |
