Old March 7th, 2022, 05:17 PM   #1
Jayden353
Motorcycle(s): Ninja 250R, CH150 Elite
new ignition wiring problems
The original ignition switch stopped turning suddenly, tried filling it with various types of lubrication, nothing worked; so instead bought a new aftermarket ignition switch and installed it. With the new switch the bike would try to start and just turn over. Came to realize that I forgot to put in a resistor with the switch. Now with the resistor put in when I turn the key nothing will come on at all. Tried putting the resistor on different wires and none of them worked, now it won't turn over.
Here is a picture of the configurations I've tried
Any sugestions would be appreciated
Jayden353 is offline   Reply With Quote
Old March 7th, 2022, 09:04 PM   #2
Hi and welcome to Ninjette! You did great job documenting wiring and what you tried.
Where are you getting info on hooking up resistor? None of those configurations are correct. Would blow multiple fuses.
1. Reverse all your mods and restore ignition-switch wiring to 100% stock condition.
2. Pull ALL fuses, including main 30a fuse and measure them. Replace any fuses that doesn't conduct electricity.
3. measure battery voltage with everything off. Voltage = ???
4. measure battery voltage during cranking. Voltage =???
Last futzed with by DannoXYZ; March 8th, 2022 at 04:45 PM.
Old March 7th, 2022, 10:37 PM   #3
Jayden353
1. returning wiring to stock doesnt fix anything because the stock ignition doesn't work anymore.
2. all fuses are good
3. voltage with the bike off is 13.3
4. cant check voltage while turning cause i cant get it to turn on anymore.
Old March 8th, 2022, 03:16 PM   #4
Something's wrong because with resistor removed and wiring restored to factory config, engine should still crank over using aftermarket ign-switch (even if it doesn't start). Undo whatever you did to get back to when engine would crank and turn over, but not start.
Verify new switch is connected to perform as follows:
Key ON
white <-- connected --> brown
red/blue <-- connected --> red
white/blk <-- connected --> white/grn + gry
Key PARK
white <-- connected --> red
No crank might also be issue with interloc safety switches.... Starter won't crank if interlocs aren't set correctly.
Last futzed with by DannoXYZ; March 8th, 2022 at 04:40 PM.
Ignition Problems nocturncal 2008 - 2012 Ninja 250R Tech Talk 7 July 11th, 2019 11:58 PM
Pregen 250 goofy ignition wiring? Jaytibba 1986 - 2007 Ninja 250R Tech Talk 4 June 5th, 2016 12:26 PM
Wiring toggle switch for ignition. nickadolph 2008 - 2012 Ninja 250R Tech Talk 21 April 10th, 2015 05:30 PM
ignition wiring rabies 1986 - 2007 Ninja 250R Tech Talk 7 August 13th, 2013 08:19 AM
Problems with ignition lock 47ninja 2008 - 2012 Ninja 250R Tech Talk 5 March 31st, 2012 09:53 AM
