Old March 15th, 2022, 06:09 AM   #1
NinjaFinally
Motorcycle(s): GPX250R 2006
Which air cleaner element to get for 2006 EX250F?
I have my tank off as I am replacing the LH switch block (horn and pass button dead). Whilst I was there, I decided to inspect the air filter. It is all rotted out and has degenerated into clumps of oily foam. See attachments.
I looked on ebay, and there are sellers with Unifilter NU2366 but they say this is only for 88-99. I did find one saying GPX250R 1996-2007, they are Whites Power Sports WPAF1293022, but they had no pictures.
Can anyone tell me which one I should buy? I am in Australia and the unifilter brand is common here.
I can see that my bike has had hardly any maintenance. I suspect that with 25,000km/16,000 miles on it that the valve clearances have never been checked. That will be my biggest job yet. Cheers.
NinjaFinally is offline   Reply With Quote
Old March 15th, 2022, 06:31 AM   #2
I'm not aware of any differences in the air filter from '99 to '06. The change was made in '08.
I like Uni Filters, and Twin Air as well.
You will need some air filter oil also. I like the the aerosol oil. Just be sure to go very lightly, or you will choke the engine, and it will run poorly. One light pass with the oil is adequate.
Old March 15th, 2022, 06:41 AM   #3
NinjaFinally
Excellent, I will get one ordered right away. Thanks
Old March 22nd, 2022, 03:40 AM   #4
NinjaFinally
So, I have my new oiled filter element installed and the bike is running well. Had to adjust the idle up a bit.
My question: What holds the lid of the airbox down? There is a strap thing that goes over a knob at the front of the air box and runs toward the battery. Looks like the strap at the battery end is supposed to have a clamp but mine has split and whatever clamp is now gone. Where is this end supposed to attach?
Thanks.
Old March 22nd, 2022, 08:06 AM   #5
There is cap with intake tunnels. Rubber strap should have metal hook end that wraps around back of battery compartment.
Old March 22nd, 2022, 12:24 PM   #6
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
K&N do a filter for these, it increases the filter area & effectively makes the airbox bigger. You need to put a self taper screw in the airbox drain hole from the outside. Its located on the bottom rear left corner.
Old March 24th, 2022, 09:16 PM   #7
bigBug
10w40 oil for the bike works but you really gotta drain all the oil from filter
bigBug is offline   Reply With Quote
Old March 25th, 2022, 06:19 AM   #8
Unlike engine oil, air filter oil has a tackiness to it that traps dirt.
Adding oil to the filter (in a bag) and trying to squeeze it out usually leaves way too much, can block airflow, and will make the engine run poorly.
One light coat of aerosol air filter oil on a clean/dry filter is usually the best.
Air Cleaner thjo0712 1986 - 2007 Ninja 250R Tech Talk 8 July 29th, 2017 02:46 PM
250R Air Filter Cleaner??? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 4 April 14th, 2010 09:49 PM
FI model 2008 - ELEMENT-AIR FILTER bogdanb 2008 - 2012 Ninja 250R Tech Talk 9 February 4th, 2010 12:42 AM
Maxima Air Filter Cleaner tlhamon 2008 - 2012 Ninja 250R Tech Talk 15 September 18th, 2009 10:22 PM
