March 24th, 2022, 09:07 PM | #1 |
Join Date: Apr 2021 Motorcycle(s): 2007 Ninja 250 Posts: 20
gas washer gasket and weird white rubbery residue all inside the carb. 07 ninja 250
Two problems
My bike has been running good after cleaning the carb, but I found two problems: 1. When I opened it there was a lot of white rubber like residue on the butterfly valves, how could prevent that from happening? 2. Second problem a non starting issue. My gas-tank had to be welded from the petcock side because the factory nut inside cracked. Long story short after re-tapping those holes they weren't perfectly straight and the tap wasn't as perfect as the factory holes and gas leaks. Now I put a Nitrile rubber gasket in between the bolt and nut but the rubber keeps deteriorating from gas. Do you guys know a rubber like material that won't deteriorate from gas to use like a washer gasket? |
March 24th, 2022, 11:03 PM | #2 |
How far off are new holes?
Do they still fit inside factory petcock gasket? Slot and angle holes in petcock so bolts can clamp down fully. |
Carb Cleaning and Air Box residue?!? | Superiorknightz | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 30th, 2017 03:21 PM |
Where do I get a gas cap gasket | nafango2 | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 28th, 2016 06:05 PM |
WTB: Exhaust gasket washer and header collar | SabreValkyrn | Items Wanted | 0 | April 17th, 2016 07:48 PM |
Really Weird carb Issue need more trouble shooting ideas | Virustech | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 24th, 2012 06:35 PM |
