May 13th, 2022, 10:01 AM | #1 |
[webbikeworld.com] - 2022 Honda PCX [Specs, Features, Photos]
Click here for full story...
2022 Honda PCX: The Economical Choice For Commuting Contents Fond of Honda’s smaller scooters but are looking for something with a little more potential for errand running? The 2022 Honda PCX was designed for getting things done, and its no-fuss attitude makes your daily commute easy and fuel-efficient. This scooter brings many more features to the table than what you would find in the highly popular Ruckus or Metropolitan. As with all motorcycles, more power = more features. This 157cc single-cylinder mill brings highway potential to Honda’s line of scooters for their 2022 model year, meaning it has a lot more commutability than some of their smaller models. To back up this recently updated 157cc engine, this Japanese-made bike features a V-Matic automatic transmission that makes riding a breeze thanks to shift-less operation so you can maximize your concentration on the road and surroundings. Honda has also included a 30L storage compartment located under the seat that with the capability of storing most regular full-face helmets. The 2022 Honda PCX starts at $3,899 USD / NA CAD On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Honda PCX in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 Honda PCX Specifications ENGINE Engine156.9cc liquid-cooled 80º single-cylinder four-strokePowerBore x Stroke60mm x 55.5mmCompression Ratio12.0:1InductionPGM-FI; 28mm throttle bodyStarterElectricValve TrainSOHC; four valvesDRIVETRAIN ClutchTransmissionAutomatic V-Matic belt driveFinal DriveCHASSIS Suspension Front31mm telescopic fork; 3.94 inches of travelSuspension RearTwin shocks; 3.7 inches of travelBrakes FrontHydraulic w/ single 220mm disc and CBSBrakes RearMechanical w/ single 130mm drum and CBSTires Front110/70-14Tires Rear130/70-13Fuel Tank Capacity2.1 gallonsColorPearl WhiteELECTRICAL IgnitionFull transistorized ignitionSpark PlugsHeadlightTail LightDIMENSIONS Overall LengthGround ClearanceTrail3.1 inchesWheelbase51.7 inchesRake (Caster Angle)26.5°Seat Height30.1 inchesCurb Weight288 pounds (Includes all standard equipment, required fluids and a full tank of fuel–ready to ride)WARRANTY WarrantyTransferable, unlimited-mileage limited warrantyExtensionExtended coverage available with a HondaCare Protection Plan® 2022 Honda PCX Features COMFORT RIDER COMFORT The long, plush seat is even more comfortable than it looks. Plus, you’ll give your co-pilot an incredible view thanks to the stepped passenger section. CONVENIENCE UNDER-SEAT STORAGE Flip the seat open and you’ll see a surprisingly large amount of storage room, enough for most full-face helmets or an evening’s worth of groceries. The main compartment locks for security and is weather-resistant, too. With a full 30 liters of capacity (nearly eight gallons), it’s plenty big enough for everyday use. EASY TO PARK The PCX gives you the choice of both a sidestand and a centerstand. That makes it easy to park for a fast dash into a store (the sidestand) or when you need to park it upright in a tighter space (the centerstand). With a lot of other scooters, you only get one or the other. ELECTRIC START Turn the key, press the button and the PCX’s fuel-injected engine starts right up and runs smooth, even in colder weather. FRESH STYLE With the PCX, you enjoy world-class style and premium features. Check out the large, central LED headlight, integrated LED turn signals, and easy-to-read LCD instrumentation, all which help give the PCX a premium look and feel. THE “X” FACTOR Take a look at the PCX’s “X”-shaped tail lamp. It uses multi-optics technology, emitting bright light in an eye-catching design. FUEL CAPACITY The PCX is incredibly fuel efficient–its large 2.1-gallon fuel tank means you can go even longer and ride even further between fill-ups. TECHNOLOGY OPTIONAL ABS The PCX offers our front-wheel Anti-Lock Braking System (ABS) giving you the power to make confident stops, even in less-than-ideal conditions. 12-VOLT CHARGING PORT The PCX features an integral USB-type socket in the fairing storage compartment, making it super easy to keep your personal electronics charged up while you’re on the go. FRAME Great handling starts with a solid chassis design, and that’s where our latest PCX really shines. It uses a duplex-cradle design rather than the more common “underbone” style. V-MATIC TRANSMISSION With the Honda V-Matic automatic transmission, just start the engine, twist the throttle and go. That means no shifting, ever—you concentrate on the road ahead and enjoy the ride! The V-Matic is a continuously variable design, so you’ll never feel it lurch from one gear to another. PERFORMANCE 4-VALVE ENGINE The PCX’s engine displaces 156.9cc, for plenty of get up and go. The eSP+ technology (enhanced smart power) uses a new four-valve design with a bore/stroke ratio specially designed to lower emissions and provide responsive performance. PGM FUEL INJECTION The PCX features liquid cooling and Programmed Fuel Injection (PGM-FI) for great performance in all traffic conditions. Plus the PCX offers impressive fuel efficiency. HYDRAULIC CAM-CHAIN ADJUSTER The engine in the PCX features a hydraulic cam-chain adjustment that’s totally automatic. This eliminates a routine maintenance point—another example of how Honda engineers make the PCX even easier to own. ROLLER BEARING CRANK The PCX engine uses special, low-friction roller bearings in the crankshaft to help give you a smooth-running powerplant that gets great mileage too. 2022 Honda PCX Photos 2022 Honda PCX Videos Honda PCX150 Review – Beyond the Ride Honda Reveals New 2022 PCX Premium Scooter Links Honda Websites Other Links The post 2022 Honda PCX [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Honda Rebel 300 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 01:35 PM |
[webbikeworld.com] - 2022 Honda CB500X [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 01:14 PM |
[webbikeworld.com] - 2022 Honda NC750X [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 01:14 PM |
[webbikeworld.com] - 2022 Honda Goldwing [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 09:40 AM |
[webbikeworld.com] - 2022 Honda CBR600RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 07:51 AM |
