Old July 3rd, 2012, 06:37 PM   #1
Pretzel
Bike won't stay running...HELP!!
I have a 2007 ninja 250 and won't idle. It takes it a minute to start up but it hardly idles, it dies out within 10 seconds of starting. It was idling alright a week ago but when I gave it gas it would cut out immediately. Now it won't idle and it still won't rev. My husband and my friend who works on bikes took the carb apart about 4 times now and cleaned it, jets and all, it has new sparkplugs (gapped correctly), adjusted needles both at the same time from top to bottom 1/4 turn each time, and has clean fuel. Please help with our engine mystery, Im DYING to ride!!
Pretzel is offline   Reply With Quote
Old July 3rd, 2012, 09:22 PM   #2
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
There might still be bad gas in the engine.... Have you tried seafoam? idle screww... jsut throwing ideas here
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old July 3rd, 2012, 09:29 PM   #3
chikenstrips
chikenstrips's Avatar
Motorcycle(s): ninja 250r
is there any vacuum leaks? also is there anythng blcking the intake/air filter?
chikenstrips is offline   Reply With Quote
Old July 4th, 2012, 08:01 AM   #4
Pretzel
Haven't tried seafoam yet, but there isn't any bad gas in the engine, no vaccum leaks, and there isn't anything blocking the intake/air filter.
Old July 4th, 2012, 10:18 AM   #5
jayman87
Motorcycle(s): 2007 ninja ex250
When my '07 ninja was having trouble idling I pulled my carbs and went to clean them but they were spotless. I was planning to do a valve adjustment before the carb cleaning but I thought the carb cleaning would fix the problem so I did it first. After that I did the valve adjustment. My valves were super tight on my cams. Once I loosened them back to spec everything ran fine.
Good Luck
jayman87 is offline   Reply With Quote
Old July 5th, 2012, 01:31 PM   #6
Pretzel
Do you remember what the specks were? I don't have a manual.
Old July 5th, 2012, 02:02 PM   #7
jayman87
Specification for intake valve clearance is .003 to .005 inches or .08 to .13 mm
Specification for exhaust valve clearance is .004 to .006 inches or .11 to .16 mm
Specification for valve adjuster locknut torque is 13 ft-lb or 18 N-m
Specification for cylinder head cover bolt torque is 87 in-lb or 9.8 N-m
Old July 6th, 2012, 07:22 PM   #8
Pretzel
Thanks soooo much!
Won't stay running after warming up skrymir69 1986 - 2007 Ninja 250R Tech Talk 31 May 1st, 2014 07:24 PM
Bike Won't Stay Running - Looking For Ideas aharnak 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2013 01:23 PM
Won't idle or stay running haze5736 1986 - 2007 Ninja 250R Tech Talk 10 March 25th, 2012 12:49 PM
bike won't stay running cabeenaz 1986 - 2007 Ninja 250R Tech Talk 42 December 20th, 2011 02:05 PM
Bike won't idle/stay running after carb removal CmichRider 1986 - 2007 Ninja 250R Tech Talk 6 August 11th, 2011 01:26 PM
