Old November 12th, 2012, 06:40 PM   #1
har0ld
Motorcycle(s): 08 ninja 250r
Valve adjustment and now bike won't stay idle
Hey guys. I did a valve adjustment on my girlfriend's 08 250r. Now the bike has a hard time starting and when it does it'll idle then the idle will start stuttering and the bike will start sputtering and then it dies. I am not sure what I could of done wrong. I followed the Vex's diy exactly. I am not sure if it's the timing, which i had a hard time getting it correct due the white dots on the cam sprockets would always unalign when i would bolt down the cam caps. I wanted to know if anyone had this issue before and what the remedy was. I want to know what to look for before I take the bike apart again. Much thanks in advance!
har0ld is offline   Reply With Quote
Old November 12th, 2012, 06:41 PM   #2
have you tried adjusting the idle speed?
Old November 12th, 2012, 06:59 PM   #3
dino74
dino74's Avatar
Did you mess with the idle screw? Shouldn't have to for a value adjustment...
Before tearing it apart again:
Are both cylinders firing? ( Both exhaust tubes hot )
Check if you put all the vacuum hoses on correctly?
CVMA #55
Old November 12th, 2012, 08:30 PM   #4
cuong-nutz
cuong-nutz's Avatar
When I did my second VA, somehow I goofed on the timing and the valves weren't shutting all the way. It's easy for the crank to move if you don't have it held in place when you have the chain off and cams out. I took it apart again and checked everything over and put it back together and it worked liked it should.
HalfFast Racing Team
Old November 13th, 2012, 12:25 AM   #5
har0ld
Yep, I tried the adjusting the idle and still nothing. I think I'm going to take it apart and retime it hopefully that will solve the issue. Thanks for the advice guys. I'll keep you posted.
Old November 13th, 2012, 07:45 AM   #6
i would double check clearances and timing
Old November 13th, 2012, 10:14 AM   #7
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
A valve adjustment is something thats better left to the professionals...
I blew the topend of my engine after a failed attempt and it would have cost me thousands to fix it. Luckily I got warranty.
At end of the day pay a couple hundred dollars and have some peace of mind. It'll be better than wasting time and the countless headaches.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old November 13th, 2012, 11:21 AM   #8
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
How did you manage that? The warranty repair, that is, not blowing the top end.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old November 13th, 2012, 12:13 PM   #9
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Poor idle is often the result of too little valve clearance, so if the valve adjustment is the only change you have made since the bike last idled well, you should double-check the clearance to be sure the valves aren't too tight. If you don't hear any clatter, this may well be your problem.
Chicagobob is offline   Reply With Quote
Old November 14th, 2012, 08:15 AM   #10
LoneRonin
LoneRonin's Avatar
Took it to a well-known shop told em I what I did, they opened it up looked inside and said it was ****ed. I had extended warranty, they said stay quiet we'll send it to the dealer tell them it came in like this. Dealer took care of the rest no questions asked...
Though I did have to wait 2 months in the prime of the season with no bike because of back ordered parts...actually 1 part. A valve...
Old December 9th, 2012, 04:45 PM   #11
har0ld
Ok, I finally got time to take the bike apart again. This time I made sure everything was aligned, double and triple checked it. So, right when I thought I was at the home stretch on finishing, I put the cct back in. The DIY said to use a flat head and turn it clockwise, but mine didn't seem like it could turn clockwise. So I tightened everything up. I checked the peep hole to make sure the crankshaft was still at the 2T mark and it wasn't . So, I took the cct off again and got the crankshaft aligned again along with the cams. Then I put the cct back in and the dam crankshaft moves again. Everytime I aligned the crankshaft at 2T it gets moved when I put the cct back in. I am not sure what I'm doing wrong. Sorry for the long explanation, but any input on how to resolve this would be greatly appreciated. Thanks.
Old December 10th, 2012, 07:20 PM   #12
krolinked
Nerd
krolinked's Avatar
Do you have the service manual? In it there is a way to align it by counting the teeth on the sprockets. You should try like this.
I can try and send you the page for how to check the teeth if you dont have the manual.
Old December 16th, 2012, 03:49 PM   #13
har0ld
Ok so I timed the cams but the crankshaft moves a little when I put in the CCT so I just bolted in down and put everything together. Started the bike up and it won't idle. If open the throttle a little it'll idle but once i let go of it or rev it the bike dies. I don't know what i'm doing wrong here. Please any help would be much appreciated.
Old December 16th, 2012, 06:16 PM   #14
har0ld
Ok after gathering myself and screaming a few times. I got the bike to work. I mess around with the shims and found that two of them where out of spec. Fixed that problem. Now i have another obstacle. I noticed an oil leak
It's coming from under the left header. I attached a picture of an engine just to give an idea of where it's leaking and it only leaks when the engine is running. It's leaking alot and I have no clue. Anybody have any insight? Thanks
Bike Won't Idle below ~2500rpm wsrussell7 2008 - 2012 Ninja 250R Tech Talk 15 May 14th, 2013 06:05 PM
Won't idle or stay running haze5736 1986 - 2007 Ninja 250R Tech Talk 10 March 25th, 2012 12:49 PM
Valve Adjustment Engine Won't Turn Over. ukie 1986 - 2007 Ninja 250R Tech Talk 86 February 15th, 2012 05:23 AM
Bike won't idle/stay running after carb removal CmichRider 1986 - 2007 Ninja 250R Tech Talk 6 August 11th, 2011 01:26 PM
Won't start after valve adjustment 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 2 June 19th, 2010 09:35 AM
