Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 General Discussion
Old June 6th, 2018, 03:51 PM   #1
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
Engine swap
Will the 400 fit the 300 frame? Just curious as my 300 only has 8.5k on it. I'm thinking there will be crashed 400s around soon.
GUZZI JOHN
john pierson is offline   Reply With Quote
Old June 6th, 2018, 04:10 PM   #2
Not a chance. The 400 has perimeter frame and engine hanging points are completely different. Also subframe, swing arm and shock bolts to 400 engine. Those areas will bump into 300 frame.
I guess if you scavenge enough of 400 frame and cut & weld pieces of 300 frame to it, that can work.
Tank from 400 also doesn’t have hump to clear backbone frame on 300. You’ll need tank for fuel-pump and EFI system. Carbs on 400 engine will lose you 5-7hp and you won’t be much faster than 300 because of extra weight over a clean 400.
Last futzed with by DannoXYZ; June 6th, 2018 at 08:16 PM.
Old June 17th, 2018, 07:58 AM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Sounds like you should have both (evil grin)
Old June 17th, 2018, 08:15 AM   #4
Yes, when in doubt, have one of each!
Engine Swap help cpayton0 1986 - 2007 Ninja 250R Tech Talk 3 October 24th, 2017 03:19 PM
engine swap iflylow General Motorcycling Discussion 4 October 24th, 2017 12:30 PM
engine swap ubxssangz 2008 - 2012 Ninja 250R Tech Talk 1 July 28th, 2013 08:29 PM
86' engine swap Birthdayninja86 1986 - 2007 Ninja 250R Tech Talk 12 March 26th, 2012 08:30 AM
engine swap almanza2010 2008 - 2012 Ninja 250R Tech Talk 12 March 16th, 2011 11:50 AM
