Old July 16th, 2013, 10:28 PM   #1
Driddle
Driddle's Avatar
Snorkel Removal
Hello everyone!
I am back with yet another question!!
I hope I don't annoy everyone.. I am just trying to learn!
Anyway! This time I'm asking about snorkel removal.
I've seen people do it. Does the extra air intake have any added advantages?
Would removing it require a power commander?
Thanks!
2008 Kawasaki Ninja 250r | Yoshimura Stainless Full Exhaust | Pazzo Levers | Puig Double Bubble | DynoJet Stage 2 | K&N Intake |
Driddle is offline   Reply With Quote
Old July 16th, 2013, 10:34 PM   #2
MagicMike
Motorcycle(s): 2012 EX250J
IMO, makes minimal difference to anything except for induction noise.
Removing it can't hurt tho
MagicMike is offline   Reply With Quote
Old July 16th, 2013, 10:35 PM   #3
JELY1990
Boring is my middle name.
JELY1990's Avatar
Motorcycle(s): '09 Ninja 250r
People take it out to increase the air in the fuel to air ratio. So basically it is done to get "better" performance. If your bike is running fine you probably don't need to do it. It's easy to take out and put back in though so you could take it out, see how the bike runs and put it back in if it has a negative or no effect.
A power commander is for FI systems. The 250r's in the USA have carbs.
JELY1990 is offline   Reply With Quote
Old July 17th, 2013, 05:34 AM   #4
DaBlue1
DaBlue1's Avatar
Originally Posted by Driddle View Post
....Does the extra air intake have any added advantages?
Yes, but only when done in conjunction with shimming the needles
DIY hint: Read this before shimming the carb needles. Really.
DIY: Shimming the carb needles
DIY: Shimming the Carb Needles... Is it for You?
DIY: Removing the Snorkel
....Would removing it require a power commander?
No power commander required.
Old July 17th, 2013, 11:38 AM   #5
bruce71198
bruce71198's Avatar
It makes a tremendous difference if you jet accordingly, especially in the upper RPM range. I can feel a real seat of the pants difference on my track bike. When I run CCS I can run without it and when I run WERA it has to be in. The pull in the upper range is much more powerful without the snorkel!!
Old July 17th, 2013, 11:51 AM   #6
Driddle
Driddle's Avatar
Thanks for the help guys!
I'm probably just going to leave it in, seeing as I don't really need to remove it, especially since I am not shimming or rejetting.
Old July 17th, 2013, 12:03 PM   #7
If you remove it, your finger will smell funny for 3 days.
Old July 17th, 2013, 02:18 PM   #8
SafetyPaws
SafetyPaws's Avatar
Motorcycle(s): Ninja 250r
www.SafetyPaws.org
SafetyPaws is offline   Reply With Quote
Old July 17th, 2013, 02:55 PM   #9
LNasty
Daily Jap rider
LNasty's Avatar
That's what she said.
Old July 18th, 2013, 07:51 PM   #10
bruce71198
bruce71198's Avatar
I stick it in and pull it out on a regular basis...haven't smelled anything unusual?
Snorkel removal questions NHrider19 2008 - 2012 Ninja 250R Tech Talk 11 June 6th, 2012 09:05 AM
Snorkel Removal on EFI Ninja 250R? hackeron 2008 - 2012 Ninja 250R Tech Talk 16 February 2nd, 2012 10:43 AM
snorkel removal 4x4kayak2112 1986 - 2007 Ninja 250R Tech Talk 14 March 9th, 2011 04:28 PM
Quick Question About Snorkel Removal LegB4Wicket 2008 - 2012 Ninja 250R Tech Talk 8 December 11th, 2010 10:49 AM
inconsistent throttle/rpm after shimming and snorkel removal Hokie11 2008 - 2012 Ninja 250R Tech Talk 3 July 23rd, 2009 03:17 PM
