Old February 26th, 2017, 05:11 PM   #1
n8Rod
Motorcycle(s): 2005 ninja 250
Ex 500 clutch assembly
Will a 2002 ex500 clutch assembly fit on a 2005 250???
n8Rod is offline   Reply With Quote
Old February 26th, 2017, 07:37 PM   #2
n8Rod
Not one reply? Really?
Old February 27th, 2017, 01:16 AM   #3
Ghostt
Ghostt's Avatar
No it will not as far as I know.
violente et ignorantia
ZX-2R BLOG
Old February 27th, 2017, 06:44 AM   #4
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
The simple answer is NO.
But there are a couple of issues here. Firstly the 500 use Chain primary drive, which I was NOT aware of until I started looking at this !
You may be able to build a hybrid clutch from 250 New gen & a 500 clutch.
The 500 clutch is the same diameter (it uses the same plates as the 250) so could possibly fit the gear wheel & shaft etc, you'd have to check. But the oil pump drive on the rear is different & the 500 uses 13 plates compared to the 9 of the 250, which means the clutch basket is much deeper so the clutch cover will not fit.
250 Clutch
http://www.kawasakioriginalparts.com...model=EX250H7F
500 Clutch
http://www.kawasakioriginalparts.com...-E9&country=GB
YMMV
Old February 27th, 2017, 07:41 AM   #5
n8Rod
Thanks for all the info. Atleast now I have a have a complete set of friction discs and steels. Would the springs be worth swapping? Thanks guys.
Old February 27th, 2017, 10:15 PM   #6
Ghostt
Ghostt's Avatar
I can say change our the clutch springs with Barnett ZX600 springs, as the OEM springs are crap, and soft
My general recommendation is to use Barnett aftermarket clutch springs for a 1985-1989 ZX-600, Part # 501-50-05055. You can view them online at the Barnett catalog, here:
http://www.barnettclutches.com/produ...&clutch_cc=600
They can be ordered through your local dealership, or at a number of online sources. Here is one such online catalog:
http://www.exoticsportbike.com/6001.htm
Another option is the EBC CSK10 (see http://www.ebcbrakes.com/motorcycle_..._springs.shtml). This kit isn't quite as stiff as the Barnett, but is better than stock and usually a little cheaper. The kit does include six springs, while the EX500 only uses five, and Ninjette uses 4.
ZX-2R BLOG
Clutch and handbrake assembly Jocaakes General Motorcycling Discussion 3 November 9th, 2013 01:56 PM
Clutch cover assembly sharky nrk Items Wanted 4 September 13th, 2013 12:16 PM
