Old May 24th, 2010, 08:30 PM   #1
LegB4Wicket
LegB4Wicket's Avatar
Motorcycle(s): 2009 Blue Kawasaki Ninja 250R
Quick Question About Snorkel Removal
Hi everyone. I have a couple of quick questions about remove the snorkel.
Last week my local shop installed my Area P exhaust and rejetted the carborators with a DynoJet kit.
The new exhaust sounds terrific and I've noticed more power and pick-up, especially at the mid-range. So far so good.
That being said, they did not remove the snorkel, depsite the instructions on the kit saying it should be done.
Should I take the bike back and ask them to remove the snorkel? Are they any disadvantages to keeping it the snorkel in place? What are the advantages of removing the snorkel?
Also I noticed on occassion there's a slight pop-pop-pop-pop sound when I sometimes downshift. It's not loud and sounds quite appealing! Is this normal?
Thank you!
LegB4Wicket is offline   Reply With Quote
Old May 24th, 2010, 08:50 PM   #2
tabogon
Motorcycle(s): 2010 Ninja 250R (Metallic Island Blue)
I might be way off, but my train of though comes from cars mainly. My assumption, you're running too lean. That sound is made from what is called valve burn, the more open exhaust reduced the back pressure and over-leaned the engine. Double check your setting from your jet kit, it may sound cool, but it can cause some pretty bad damage if not corrected.
http://dudetravel.blogspot.com/
tabogon is offline   Reply With Quote
Old May 24th, 2010, 09:09 PM   #3
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
No point taking it back to the shops to remove the snorkle, its a 5min job tops and even a 5 year old could do it.
Heres the DIY: DIY: Removing the Snorkle
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old May 24th, 2010, 09:17 PM   #4
I'd take it back on principle alone. If they had read the Dynojet instructions for the jet kit, it tells you to remove the snorkel when you install their jet kit. pull it out and most likely you're bike will pull harder at the upper revs.
http://www.dynojet.com/pdf/2193.pdf
You're backfiring is due to the Kleen system which you should remove when you have a full exhaust and jet kit installed.
Last futzed with by kkim; May 28th, 2010 at 12:24 AM.
Old May 25th, 2010, 06:18 AM   #5
tabogon
I didn't even think of the Kleen system, good thinking Kelly.
Old May 25th, 2010, 12:25 PM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
At least you didn't say "even a caveman could do it."
Old May 25th, 2010, 05:26 PM   #7
g21-30
g21-30's Avatar
Nope, cavemen couldn't do it, since they couldn't read the DIY!
Old May 27th, 2010, 08:12 PM   #8
LegB4Wicket
Thank you for the advice everyone.
I'll have the Kleen system removed and see it that puts an ends to the noise. It only seems to happen when I pull in the clutch lever and going downhill.
I spoke with the shop about the snorkel. They stated they have not seen any difference in results with it removed but, did mentioned the snorkel does offer added protection against water entering the airbox. It rains a lot here on Vancouver Island, so I'll keep it in for now.
LBW
Old December 11th, 2010, 10:49 AM   #9
hackeron
Motorcycle(s): Ninja 250r (2009)
What would the effect be on a Fuel Injection version of the bike? - Since rejetting or anything like that isn't needed and the air/fuel mixture is adjusted on the fly by the fuel injection, more airflow means more hp?
hackeron is offline   Reply With Quote
Snorkel Removal Driddle 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2013 07:51 PM
Snorkel removal questions NHrider19 2008 - 2012 Ninja 250R Tech Talk 11 June 6th, 2012 09:05 AM
Quick Airbox removal question forevertwowheels 2008 - 2012 Ninja 250R Tech Talk 11 June 14th, 2011 04:31 PM
Quick question, spark plug removal Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 4 April 21st, 2011 08:11 PM
snorkel removal 4x4kayak2112 1986 - 2007 Ninja 250R Tech Talk 14 March 9th, 2011 04:28 PM
