October 9th, 2011, 02:30 PM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
Fuel Gauge not working
So I'm finally finishing up all of the work on my bike. One of the last hiccups is the fuel gage's unwillingness to cooperate. And yes, I do have that little wire clip thing attached. My main concern comes from this: On my fuel tank, I currently have a total of THREE tubes attached. Two are going to the petcock, and one is a vacuum tube going to the left side of the tank. Now it looks like there is a place one the fuel sensor thing on the bottom of the tank for another tube, but all of my tubes are going somewhere. So am I missing a tube? Am I retarded?
October 9th, 2011, 02:53 PM | #2 | |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
I took out my carbs to clean them, while putting bike back together, I have a hose from between the carbs... that I could remb goes to where. I connected it to the "FUEL SENSOR" (black) under the tank, right side, but my bike dont even start now. I dont even remb if anything goes to it. My 2009 ISNT the california model, is yours? |
October 9th, 2011, 07:37 PM | #3 |
No mine is not the CA model. So you're saying there is a tube that goes to the black fuel sensor under the tank?
October 10th, 2011, 09:06 AM | #4 | |
its clear that, that nothing is to be connected to the black fuel sensor except for the WIREs that plugs into it, lol. |
October 10th, 2011, 09:14 AM | #5 |
Hmmm… so any other ideas why the gage isn't working?
October 10th, 2011, 09:22 AM | #6 |
What do you mean by not working? Doesn't read full, always says empty, etc?
October 10th, 2011, 09:31 AM | #7 |
It reads completely empty...
October 10th, 2011, 10:29 AM | #8 |
Your issue is probably electronic then and shouldn't have to do with those tubes (unless your tank is actually empty ). The easiest thing to check is the fuel sender connector which has a green tab is connected.
It should only connect one way and clicks into the other tab. If that's secure, you might have jarred a wire loose behind the dash. |
October 10th, 2011, 11:07 AM | #9 |
I'm not at home so I can't just look; do the gages need taken apart to see if there is a wire loose?
October 10th, 2011, 04:24 PM | #10 |
I think, you only need to remove the windscreen, then the 4 chrome hex bolts on the dash (2 are used for the Mirror mounts) then that whole panel should come off to allow you access to the gauges wiring.
Replace Fuel Gauge with Fuel Light? | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 2nd, 2014 08:33 AM |
My video on how to fix the fuel sender for your fuel gauge | Klint | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 2nd, 2013 09:04 PM |
Fuel tank/Fuel gauge issues | coolcatjames | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 23rd, 2012 06:25 PM |
Fuel gauge not working | jdoucet93 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 15th, 2011 10:07 PM |
fuel gauge | shellneil | General Motorcycling Discussion | 8 | November 1st, 2009 02:26 PM |
