Old October 8th, 2012, 07:16 PM   #1
Surferboy120
Finding some curves....
Motorcycle(s): 2013 300 Ninja
Not a DIY OIL Change just a view and some info
Since the 300 is new to Kawasaki line up I thought I would share the effort put into changing the oil. Which is nothing. Absolutely an easy easy easy task.
Some Kawasaki 10W-40 non synthetic until after the second oil change.
And the lazy mans way of taking the oil filter off. As Jiggles pointed out with his 1000 the factory does seem to put the oil filter on stupidly tight. The plastic oil filter socket does the trick with ease so maybe it was me being lazy this day.
Surferboy120 is offline   Reply With Quote
Old October 8th, 2012, 10:02 PM   #2
Old October 8th, 2012, 11:23 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Why shouldn't you use synthetic before 1000 miles?
AFM #676
Supersports are for n00bs
Old October 8th, 2012, 11:37 PM   #4
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
non syn allows the rings bed into the liner.
to get the right "shape"
thats why engine builders when they hone the cylinder bores they leave cross hatch "effect" and not shiny.
ninja250r81 is offline   Reply With Quote
Old October 8th, 2012, 11:44 PM   #5
Jiggles
Jiggles's Avatar
MOTM - Apr '13
OH welllllllll I put synthetic in at 600. I'm sure if I just redline all day I'll get the same effect
AFM #676
DIY- Oil Change kkim 2008 - 2012 Ninja 250R Tech Talk 499 March 1st, 2019 09:31 AM
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
Good info for noobs. Video DIY's rallyegolf 2008 - 2012 Ninja 250R Tech Talk 5 March 6th, 2009 01:50 PM
