October 16th, 2016, 04:43 AM | #1 |
[motorcycle.com] - Church Of MO First Ride: 1999 Yamaha YZF-R6
The announcement*of the 2017 Yamaha YZF-R6 – with new electronics but the same ‘ol engine – should be considered a jolt of excitement for the supersport world. While it’s a little disappointing to not see any engine upgrades for 2017, the fact the bike is getting any updates at all is a positive sign. And if you’re a little let down by the new R6 like I am, at least the updated appearance of the Yamaha is stunning. When I think of good looking R6 models, however, I’m still smitten with the first-generation models from the late 1990s. Not only did they look good, but they were excellent performers, too, as the MO staff of 1998 excitedly point out in the opening sentence. So for this Church feature, it’s only right that we dig deep into the MO archives and reprint the first article we have of the YZF-R6 (err… the first one we have that didn’t get lost in the chasm of internet servers when MO changed ownership). Check out the price of the bike then: $7,999! Compare that to the $12,199 Yamaha is asking for the 2017 version! First Ride: 1999 Yamaha YZF-R6 By MO Staff, Nov. 11, 1998 Photos by David Dewhurst and Yamaha Motors USA PHILLIP ISLAND, AUSTRALIA, November 11, 1998 — Never mind the bollocks, we’ll get right to the point: The Yamaha YZF-R6 kicks ass. It is one of the most feral, thrilling, heart-pounding motorcycles we’ve ever ridden. Yeah, yeah, don’t many journalists use over-the-top superlatives in order to mollify manufacturers and help pay for the ad guy’s mortgage? Yes, it happens, but this time we really mean it. I remember coming out of the 165 mph front straight at Phillip Island as my heart pounded with a violent, lucid exhilaration bordering on an ecstatic clairvoyance that lasted until I low-sided into the gentle South Pacific mist,” said tester Aaron “Elmo” Hammel. Translation: Our test bike was the best, fastest 600 ever until Elmo crashed it. In four-and-one-half years and hundreds of bikes reviewed, that was the first Yamaha we’ve ever wadded. Oops. Aaron “Elmo” Hammel post low-side. Basically, if the YZF-R6 could be bottled and sold on street corners we’d end up junkies, trading in our homes for shopping carts, hanging around recycling centers, rummaging through trash bins for cans and bottles, anything to scrounge up enough cash for one more glorious hit at 15,500 revolutions per minute. Rehab be damned. Giga-high revs can do that to a person. The YZF-R6’s engine begins to kick in at 9000 rpm, but at 11,000 rpm — where most sportbikes begin to peak — the R6 starts pulling and shrieking all the way to the 15,500 redline, virtually uncharted territory for a production four-stroke motorcycle. There’s isn’t much power down low, and initially we were tempted to slip the clutch in order to punch up into the higher rev range, but the R6 motor spins quickly and reaches its preferred powerband smoothly and almost instantaneously. Yamaha achieved this high-revving performance by designing a completely new engine utilizing low internal friction, an optimized ram-air induction system and direct ignition. It features side-driven camshafts that allow the R6 not only to keep the engine width at a minimum but also permit equal spacing between the cylinders to help ensure uniform heat dissipation, an important feature in a high-revving, high-performance engine. Yamaha also incorporated the use of equal length inlet tracks for the R6’s smooth, immediate pick-up. Despite protests to the contrary, Yamaha claims the YZF-R6 is equipped with their first true ram air system. Cool air is directed, or rammed, at high pressure into a large capacity airbox and thrust into the 37mm carbs, where vertical, equal-length inlet tracts push the air/fuel mixture into the high compression (12.4:1) combustion chambers that, together with dual-electrode spark plugs and plug-mounted ignition coils, allow the R6 to maintain is high-rev powerband. This high-compression, high-spinning, high-revving firing puts a little more stress on moving parts, particularly valve springs. In response, Yamaha designed valve springs which they claim are lighter and 20 percent stronger than standard valves. Other lighter, lower friction parts Yamaha incorporated into the R6’s powerplant include low-friction bearings, ceramic-plated cylinders and lighter pistons, con rods and crankshaft. A deeper oil pan also allows for less oil friction. At 10,500 rpm the YZF-R6 is merely warming up. As usual, this attractive silver and blue color combo isn’t coming to the States. How come, if the U.S. is expected to bankroll the IMF, we can’t get cool motorcycle color schemes in return? Seems like a fair trade to us. The valve springs have been made of a “VX” rated steel that simply means it’s a “stronger” steel. The rigid, one-piece aluminum cylinder/crankcase offers superior heat dissipation. The extra-long, truss-style aluminum swingarm pivots closer to the bike’s center of gravity, allowing for a stable ride on such a short wheelbase (54.4″/1382mm) motorcycle. The same four-pot brakes that worked great on the R1 performed equally well on the R6. Yamaha says all this adds to a claimed 120 hp with ram air at the crank or 108 bhp stationary. We measured the CBR600F4 at 98.9 bhp and the R6 feels more powerful. For you power junkies, expect about 107 bhp measured on the dyno and a little more at speed with ram air. That’s an astronomical figure for a 600cc engine, making the R6 the world’s first 600cc production four-stroke motorcycle producing over 100 bhp in box-stock form. * Another feature of the R6 engine is the one-piece crankcase that makes the engine not only smaller and lighter but stiffer, allowing it to act as a fully-stressed member of the new chassis. A lighter aluminum, twin-spar Deltabox frame with a three-axis layout gives the YZF-R6 the shortest wheelbase in its class. The compact engine also allows for the use of an extra-long swingarm for better stability. The YZF-R6 is a very stable, easy-to-control motorcycle. Ergonomics are similar to the YZF-R1: The rider sits over the front wheel and the footpegs are moderately rear-set, yet the riding position is very comfortable, more than adequate for the street. We suspect, however, riders over 6’1″ may feel a little cramped. Even though they look similar, the R6 is not a down-sized R1. It provides an entirely different riding sensation. The cornering method on the R1 requires late braking, flicking the bike in through a short corner then flipping the bike back upright and accelerating. The R6 is designed to be ridden carrying high corner speed, braking early then accelerating hard out of long corners. The R6 turns quickly but we found it does have a slight tendency to want to run wide, although this may be a characteristic of the test bikes’ Bridgestone tires that will come with the European models (D207s in the States). And while the R1 will head shake on corner exits under hard acceleration, the R6 stays planted. With a 56° lean angle, ground clearance is excellent, and we worked hard to drag something in the corners, yet we didn’t and eventually we gave up trying. Lastly, while the powerful R1 is almost violently fast out of corners, the R6 gives the same sensation, just neither as brutal nor as explosive. The YZF-R6 handles and feels like a 250cc GP motorcycle. Overall wheelbase is 54.4 inches (1382 mm) and its claimed dry weight is 370 pounds (168 kg), which, if Yamaha’s measurements hold true, will make it the YZF-R6 the lightest and most compact motorcycle in its class. The R6 is equipped with fully adjustable 43mm front forks and a fully adjustable monoshock rear suspension. Like the R1, the YZF-R6 is well-valved and it feels taut without being too stiff. The brakes are superb, with dual 295mm floating disc rotors and the R1’s excellent four-piston calipers up front. The rear brake is a little soft, although this is common to most high-performance supersport motorcycles. We have ridden the YZF-R6 and Honda’s CBR600F4 within a few days of each other and while they’re both very agile and fast, the F4 might be a friendlier, more all-around streetbike while the R6 is a more extreme motorcycle designed for more experienced riders. We are not saying that the F4 isn’t exciting or the R6 isn’t easy to ride, it’s just that Yamaha and Honda have slightly different philosophies regarding market position and design. Honda is replacing the F3 with the all-new F4, and their engineers had to meet the challenge of improving performance and handling enough to win Supersport Championships while not sacrificing the comfort that helped make it the best-selling 600cc motorcycle in the world. Yamaha, on the other hand, intends to continue producing the YZF-600 and market it as an all-purpose sport bike while positioning the R6 as an ultra-high-performance 600cc motorcycle capable of not only dominating its class but also stealing market share away from the 750cc supersport class as well. Elmo pre low-side. The good news for Americans is that the YZF-R6 is coming to the States this model year. MSRP is $7999.00 USD. With new, high-performance*motorcycles from all four major 600cc supersport manufacturers and essentially only two four-cylinder 750cc production supersports, neither of which have been redesigned in three years (a generation in supersport years), the YZF-R6 may indeed herald the end of the 750cc supersport class as we know it. It will be interesting to see if Team Yamaha USA’s Tommy Hayden — who, rumor has it, plans to contest the AMA 750cc Supersport Championship on a YZF-R6 — can win a title. But we really won’t know whether the 750cc supersport production class is doomed unless we gather all four 600cc bikes and ride them back-to-back. Maybe we will throw in a GSX-R750 for good measure. In any case, stay tuned. Church Of MO – First Ride: 1999 Yamaha YZF-R6 appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - Church Of MO 1999 Yamaha Customs | Ninjette Newsbot | Motorcycling News | 0 | April 12th, 2015 09:50 AM |
[motorcycle.com] - Church Of MO First Ride: 2002 Yamaha YZF-R1 | Ninjette Newsbot | Motorcycling News | 0 | February 22nd, 2015 06:30 AM |
[motorcycle.com] - 2015 Yamaha YZF-R1/YZF-R1M First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | February 21st, 2015 01:50 AM |
[motorcycle.com] - Church Of MO First Ride: Y2K Yamaha YZF-R1 | Ninjette Newsbot | Motorcycling News | 0 | February 15th, 2015 08:22 AM |
[motorcycle.com] - Church Of MO First Ride: Yamaha BT1100 Bulldog | Ninjette Newsbot | Motorcycling News | 0 | October 19th, 2014 08:40 AM |
