April 26th, 2013, 11:03 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
2009 Ninja 250 running bad - Need urgent help!!
I was doing about 50-60mph in 6th gear when all of a sudden the bike started sounding really strange. The exhaust note got much deeper and I felt a loss of power as well. I pulled over to the shoulder and tried to figure out what was wrong but eventually had the bike towed home because it wouldn't run properly.
I've noticed a few things so far: 1) The bike will barely idle now, even with the choke on. It also seems to be backfiring when I rev the bike up a little. 2) The bike won't really rev up. I twisted the throttle and there was hardly any response. I had just refueled and rode about 20 miles when this happened. Could a bad batch of gas damaged something? Or could the spark plugs be fouled up? I just changed them a few months ago. I can take a video if that will help. Thanks. |
April 26th, 2013, 11:18 AM | #2 |
video would help.
how many miles on the bike? when was the last service?
April 26th, 2013, 11:46 AM | #4 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
or the exhaust flange came loose on one or both sides.
April 26th, 2013, 11:52 AM | #5 |
since everybody else is guessing, i'll pick the vacuum hose popped off or is leaking
April 26th, 2013, 11:52 AM | #6 |
One of the spark plug ignition wires was loose so I guess the bike was running with only one spark plug?
April 26th, 2013, 12:00 PM | #7 | |
Similar thing happens when some of the plugs going into the coils get loose after a valve service. A cylinder feels cold, while the other feels normally hot.
April 26th, 2013, 12:20 PM | #9 |
Do not discard advice of post #3 above.
Did you check it?
April 26th, 2013, 12:44 PM | #10 |
I'm going to go ahead and replace both spark plugs right now. I'm hoping my gas mileage will be better now too. Last time I only got 48mpg even after riding conservatively on the highway for 123 miles.
How do I check the air intake? |
April 26th, 2013, 12:47 PM | #11 |
48mpg is great. i only get about 35.
to check intake snorkel, remove the rear seat, look down the tail. the intake is on the right hand (throttle hand) side at the bottom of the tail... theres usualyl manuals and stuff in there that can slide down and block the intake.
April 26th, 2013, 12:51 PM | #12 |
You should see a mechanic.............quick ...........
April 26th, 2013, 01:39 PM | #14 |
48mpg is bad considering I accelerated like a granny and shifted into 6th gear by 40-45mph and 99% of the 123 miles were on the highway.
I replaced both of the spark plugs and the bike seems to be running fine now. I'm worried about the spark plug ignition wires coming loose again though. They seem to be seated properly but I hope I don't have an issue with them after riding a few thousand miles. |
April 26th, 2013, 02:29 PM | #15 | |
Join Date: Feb 2010 Motorcycle(s): 2008 NINJA 250, BLACK, 650 NINJA 2009, RED, F 650GS BMW 2012 YELLOW Posts: 94
2007 ninja 250 HELP ME GET IT RUNNING | mjsyard | 1986 - 2007 Ninja 250R Tech Talk | 19 | April 23rd, 2014 06:59 AM |
2009 ninja 250 running rough | AZninja | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 5th, 2012 01:07 AM |
Running ninjette with no muffler, bad idea?? | venmichaels | 2008 - 2012 Ninja 250R Tech Talk | 18 | October 13th, 2011 04:07 PM |
