Old August 19th, 2010, 11:28 AM   #1
splittrain
splittrain's Avatar
Unhappy Help Please! Clutch not engaging!
Okay so I installed Woodcraft Clipons and Pazzo Shorty Levers today. It all went smooth until after I installed everything but the new clutch lever. I removed the pivot bolt and nut from the clutch side stock lever. Then I proceeded to remove the cable end and insert it into the new lever. I put on the new lever and tested it out (while the rear stand is in use) and I sat on it. I fired her up, kicked hewr into first while holding in the clutch and the wheel kept moving... So what is wrong with it! Idk if i need to adjust the cable or not.
Suggestions? help is encouraged
splittrain is offline   Reply With Quote
Old August 19th, 2010, 11:33 AM   #2
dubojr1
dubojr1's Avatar
It is normal for the rear wheel to move some when in gear. Apply the rear brake to see if it stops. If it stops the wheel then your good. If it stalls the engine the I would say you need to adjust your clutch cable. See you owner's manual for specs.
Old August 19th, 2010, 11:42 AM   #3
splittrain
splittrain's Avatar
Wow lemme check.. Maybe i shud take it off rear stand and try it? lol brb
Old August 19th, 2010, 11:53 AM   #4
splittrain
splittrain's Avatar
Yea so its fine now lol thanks bro. I took it off the rear stand and the clutch was fine! Any recommendations for premium adjustment for the clutch cable? the words in the owners manual are kinda confusing to me lol
Old August 19th, 2010, 12:00 PM   #5
dubojr1
dubojr1's Avatar
I always adjust mine to where I am comfortable with its engagment point. Here is the instructions from the service manual. See if it helps you any.
Old August 19th, 2010, 12:21 PM   #6
splittrain
splittrain's Avatar
Thanks!
Old August 19th, 2010, 12:22 PM   #7
dubojr1
dubojr1's Avatar
No problem!
Welcome to our community!
Old August 19th, 2010, 12:27 PM   #8
splittrain
splittrain's Avatar
Smile
Thanks! I love this place. I am a semi-lurker but I post on occasion. The DIYs have saved me hundreds of shekels!
Old August 19th, 2010, 12:33 PM   #9
dubojr1
dubojr1's Avatar
That's cool. Try to "pay it forward" when you can.
Old August 19th, 2010, 12:35 PM   #10
splittrain
splittrain's Avatar
I will try. I would ask what you mean, but I think I should find out on my own, since that phrase is everywhere on this site
Old August 19th, 2010, 12:41 PM   #11
dubojr1
dubojr1's Avatar
It's simple...
When someone has done something nice for you, then you should try to do something nice for someone else. We all should do our part to make this a better world.
Old August 19th, 2010, 12:46 PM   #12
splittrain
splittrain's Avatar
Thanks for that. Il do my best!
Old August 19th, 2010, 12:54 PM   #13
The wheel will spin in 1st even with the clutch held in. I discovered this the first time I ever got it up on a rear stand.
Old August 19th, 2010, 01:43 PM   #14
Originally Posted by dubojr1 View Post
It's simple...
yep, what a great concept... for this forum and the world.
try it... it works!!
*Target Locked On* Engaging xaple Videos 62 June 28th, 2018 10:25 PM
Clutch not fully engaging? greenmachine 2008 - 2012 Ninja 250R Tech Talk 3 August 10th, 2013 01:05 PM
Why is my Clutch not fully engaging? Kbeezer101 1986 - 2007 Ninja 250R Tech Talk 16 November 23rd, 2012 06:12 PM
Front brake not engaging SabreValkyrn 1986 - 2007 Ninja 250R Tech Talk 12 November 9th, 2012 12:22 PM
Engaging clutch to shift.. Penguin250 Riding Skills 25 May 29th, 2011 08:03 PM
