Old July 12th, 2013, 05:26 PM   #1
razingman
Motorcycle(s): NOne
Front bolt / fork question
So I got home today and this bolt is missing and you can clearly see though the assembly. I honestly don't know how I lost it as I drove about 50km and when I started it was there. Does anyone know what this part is called and if the bolt was there would it still be hollow?
razingman is offline   Reply With Quote
Old July 12th, 2013, 06:02 PM   #2
keeblerkhan
Motorcycle(s): 250J
92154-0075-18R BOLT,FLANGED,16X22,F.
Yes it will still be still be "hollow" from underneath the lower triple clamp. The bolt is not that long.
keeblerkhan is offline   Reply With Quote
Old July 12th, 2013, 06:06 PM   #3
razingman
Motorcycle(s): NOne
Okay, good. I didn't know if there was a bolt on the bottom too. How mission critical is this part? My parts store is closed on weekends..
Old July 12th, 2013, 06:37 PM   #4
keeblerkhan
Motorcycle(s): 250J
I definitely wouldn't ride without it. You could probably get a way with it for a little while, but your steering bearings could theoretically loosen up and that's not really a good thing while at speed.
Old July 12th, 2013, 06:38 PM   #5
razingman
Motorcycle(s): NOne
Figured, okay I guess I am grounded for a while
Fork drain bolt washer Sipper' 1986 - 2007 Ninja 250R Tech Talk 3 May 27th, 2014 11:27 AM
front fork disassembly question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 9 October 19th, 2013 06:30 PM
Fork drain bolt is stuck Graugaard 1986 - 2007 Ninja 250R Tech Talk 20 April 19th, 2013 09:36 AM
Front fender bolt question divingtigger 2008 - 2012 Ninja 250R Tech Talk 5 July 18th, 2009 06:38 AM
missing fork clamp bolt boyonfire 1986 - 2007 Ninja 250R Tech Talk 11 June 2nd, 2009 04:24 AM
