Old May 1st, 2014, 06:24 PM   #1
snot
sammich maker
snot's Avatar
MOTM - Apr '15
front wheel bearings
Any tricks for getting the bearings out of the front rim?
I searched and could not find any info.
Thanks in advance!
Old May 1st, 2014, 06:26 PM   #2
Thanks in advance!
Heat + gravity
Old May 1st, 2014, 06:48 PM   #3
so if you pour enough liquid nitrogen onto the bearing, the cold will make it contract.
then just give it a little tap and presto. bearing is now dust.
Old May 1st, 2014, 07:09 PM   #4
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Tried a heat gun, hammer and socket. No movement. I may need to take to a shop.
Old May 1st, 2014, 07:21 PM   #5
http://faq.ninja250.org/wiki/Replaci...wheel_bearings
http://www.dansmc.com/wheelbearing.htm
Old May 2nd, 2014, 06:06 AM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Anyone know if a press can be used or if the wheel tapers on the inside?
Old May 2nd, 2014, 06:15 AM   #7
Pretty sure a slide-hammer style bearing puller is what you want. Harbor Freight has one that I've heard is adequate for occasional use.
Heating up the wheel should help.
When it's time to install the new bearings, put the bearing in the freezer for a while and heat up the wheel. The thermal expansion/contraction difference will make it a lot easier to install.
Old May 12th, 2014, 03:15 PM   #8
I've looked at puller after puller at HF and haven't seen one that looked appropriate. Which one?
Old May 12th, 2014, 03:17 PM   #9
there isn't much lip to get blind bearing pullers on the inside with. i've never had any luck without tapping it out from the opposite side
Old May 12th, 2014, 03:59 PM   #10
What I don't get is how heating the wheel hub supposedly expands the chamber the bearing fits into. Expands the metal? Sure. I get that. At the atomic scale, the atoms expand and, thus, so does the material, but that wouldn't make the chamber expand as I understand it.
The way I visualize it is that it only helps if the aluminum is somehow magically only expanding outward from the bearing and, thus, widening the hole/loosening the fit. In reality, I would expect it to expand in ALL directions which means it would also expand in, putting MORE pressure on the bearing (especially considering that the bearing has also expanded outward however little). A heated ring would increase in outer diameter but the inner diameter would only increase to make room for the circular expansion (it doesn't just expand in/out). A wheel hub has enough material everywhere else that I don't see that phenomenon applying.
I don't doubt that it does make it easier, but is that really why? Could it be that the metal is simply softer and conforming to the forces you apply? If so, then it may cause you to lose more aluminum with the steel bearing than you would have otherwise.
Old May 12th, 2014, 04:45 PM   #11
when you heat both metals up (bearing and the thing its touching) they expand even from the inside and push on each other, slightly compressing the touching surfaces into each other. when they cool, they contract and theres a bit of a gap until the metals smoosh back together from other compression and oxidation and crap. the amount it moves is not very much but with such tight tolerance, just a little bit makes it loose enough to free up a bit
......maybe
Old May 12th, 2014, 04:55 PM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Took mine to the dealer, $60.00 this included mount an balance of new rubber.
Old May 14th, 2014, 05:57 PM   #13
mgentz
Board Member
I bought a wheel bearing puller to get mine out. $70 one time charge. Now I can do any bike I ever need to.
3 Rear Wheel Bearings. Where Does The 3rd Go? az3200 1986 - 2007 Ninja 250R Tech Talk 5 June 15th, 2014 07:21 AM
Wtb shifter assembly,front forks,front wheel and bearings Rumple Items Wanted 1 June 24th, 2013 12:06 PM
replace wheel bearings cuz 2008 - 2012 Ninja 250R Tech Talk 7 May 3rd, 2013 05:03 PM
Wheel Bearings: Similar to 250? Rekognize 2013 - 2017 Ninja 300 Tech Talk 9 April 21st, 2013 06:37 AM
Full set of new double sealed wheel bearings Zim Motorcycle-related 11 April 21st, 2010 07:47 PM
