May 27th, 2014, 03:59 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): '01 Ninja 250 Posts: 62
Swingarm Bearings?
So in the process of my rebuild I pulled the swing arm off and it is rusty as hell. It needs a sand blasting and some powder coating. Do the bearings in the swing arm have to be pressed out or do they come out else wise? Once out can the old bearings and such go back in (assuming they cleaned up okay)?
May 27th, 2014, 04:06 PM | #2 |
once you take off the oil seal you should be able to pull out the inner race and use a blind bearing puller on the needle bearings. i don't know if they are caged or not.
May 27th, 2014, 04:22 PM | #3 | |
Yes. http://faq.ninja250.org/wiki/Servicing_the_swingarm
How ball bearings are made | Motofool | General Motorcycling Discussion | 5 | June 6th, 2016 06:49 AM |
3 Rear Wheel Bearings. Where Does The 3rd Go? | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 15th, 2014 07:21 AM |
front wheel bearings | snot | 2013 - 2017 Ninja 300 Tech Talk | 12 | May 14th, 2014 05:57 PM |
replace wheel bearings | cuz | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 3rd, 2013 05:03 PM |
Wheel Bearings: Similar to 250? | Rekognize | 2013 - 2017 Ninja 300 Tech Talk | 9 | April 21st, 2013 06:37 AM |
