Old May 12th, 2015, 05:13 PM   #1
nickk_pike
Motorcycle(s): Ninja 250 Gokart
Spark Plug not sparking? PLEASE HELP
I recently have bought all the parts to put together a 2008 Ninja 250R, (Risky) I am currently 16 years old and plan on mounting this engine in my current 150cc 7HP engine lol. I have everything working, the electric start works, everything.. Except the spark plugs. I'm not 100% sure how to wire the coils, Yes I did ground them, I also grounded everything else that was needed to be grounded. BUT, the spark plugs just don't spark, any help, please!? THANKS SO MUCH.
nickk_pike is offline   Reply With Quote
Old May 12th, 2015, 05:45 PM   #2
xorbe
xorbe's Avatar
Pic of your setup with drawing on it how things are wired currently?
Old May 12th, 2015, 06:56 PM   #3
nickk_pike
File Type: mov trim.6C14BF0C-A49E-43C2-B084-4BC48A531F99.MOV (21.21 MB, 28 views)
Old May 12th, 2015, 06:58 PM   #4
nickk_pike
As of rightnow, everything is wired stock. What would be something that would cause it to not spark?
Old May 12th, 2015, 07:44 PM   #5
Welcome, Nick !!!
Is there electrical continuity between the engine and the negative pole of the battery?
Old May 12th, 2015, 10:57 PM   #6
Ghostt
Ghostt's Avatar
Are you using the OEM key? Because there is a 100 ohm resistor in there to prevent "HOT WIRING".
If your not using the OEM set up, then you need to add a 100ohm resistor, please see to wiring diaphragm(pdf) below.
Good luck
File Type: pdf Start_&_Ignition_Troubleshoot_Schematic-1.pdf (65.1 KB, 16 views)
File Type: pdf Ninja_250_Start_&_Ignition_Schematic-1.pdf (56.2 KB, 23 views)
violente et ignorantia
ZX-2R BLOG
Old May 13th, 2015, 04:07 AM   #7
nickk_pike
thanks for all the amazingly fast replies! Yes I am using the OEM key, and yes I do continuity between the engine/battery. thanks
Old May 13th, 2015, 04:09 AM   #8
nickk_pike
Well not the oem key, I'm using one that I bought from eBay, a replacement one. Do I still need that resistor? thanks again!
Old May 13th, 2015, 06:52 AM   #9
cuong-nutz
cuong-nutz's Avatar
Yes. I repinned the Chinese eBay ignition switch/lock because how they set it up is not up to standard. Regardless, you need to add a 100 ohm resistor to make it work.
HalfFast Racing Team
Old May 13th, 2015, 08:12 AM   #10
nickk_pike
Just so make sure. I need the resistor to make the spark plugs fire?
Old May 13th, 2015, 08:20 AM   #11
EMSRacer07
EMSRacer07's Avatar
yes. Without the resistor the ignition system wont work. You can get a few at radio shack for a dollar or so.
Old May 13th, 2015, 08:58 AM   #12
Ghostt
Ghostt's Avatar
thought so, and be sure to install the new resistor properly.
ZX-2R BLOG
Old May 13th, 2015, 10:34 AM   #13
nickk_pike
Sorry if I'm asking too many questions.. I've wired everything BUT a motorcycle. The electric starter stills turns over without the resistor, is that normal?
Old May 13th, 2015, 10:45 AM   #14
Ghostt
Ghostt's Avatar
Yes
ZX-2R BLOG
Old May 13th, 2015, 11:00 AM   #15
EMSRacer07
EMSRacer07's Avatar
what he said ^^^^^^^^^^ the anti theft just keeps the ignition from working. It will turn over etc but wont power the plugs.
Old May 13th, 2015, 11:55 AM   #16
Ghostt
Ghostt's Avatar
It part of the ignition circuit, nothing to do with the starter circuit.
ZX-2R BLOG
Old May 13th, 2015, 11:57 AM   #17
nickk_pike
Thank yall so much, I'll check about the resistors when I get home. one more thing, does anyone have any idea on which wires plug into which side of the ignition coils? There is a green side and a black side.. Thanks
Old May 13th, 2015, 03:19 PM   #18
nickk_pike
Nothing happened with the resistor. I used a 1 watt 100Ohm resister, was it supposed to be a half watt? please reply ASAP. thanks
Old May 13th, 2015, 03:50 PM   #19
EMSRacer07
EMSRacer07's Avatar
it has to be the right voltage coming out of the ignition switch. I remember I bought a ebay switch i had to run 2 100 ohm resistors together to get the voltage in the "safe area". Try one more.
Old May 13th, 2015, 03:53 PM   #20
cuong-nutz
cuong-nutz's Avatar
How did you wire the resistor? I took mine apart and soldered it in.
Old May 13th, 2015, 03:55 PM   #21
EMSRacer07
EMSRacer07's Avatar
it can be done after the switch as well doesnt have to be done on the switch. just fyi. But its possible it just didnt drop the voltage enough. Try two.
Old May 13th, 2015, 03:57 PM   #22
nickk_pike
it goes to the gray wire?
Old May 13th, 2015, 03:59 PM   #23
EMSRacer07
EMSRacer07's Avatar
colors could vary with the aftermarket ignition switch. I think mine was a different color than on the main wiring harness. But on the harness I beleive it connects to a grey wire like the schematic above.
Old May 13th, 2015, 04:02 PM   #24
nickk_pike
I have a .5 Watt resistor in there at the moment.. tried a 1 watt.. nothing happend, so (2) 1 watt resistors?
Old May 13th, 2015, 04:03 PM   #25
EMSRacer07
EMSRacer07's Avatar
I guess we shall assume that you did it right, are the other safety switches right? Like the motor in neutral, kickstand down sensor, and make sure all the fuses are good. Check the fuse for ignition.
Just throwing stuff out there to check. I still would wire in another resistor. Thats what I had to do to get the voltage right.
Old May 13th, 2015, 04:07 PM   #26
nickk_pike
these are my wiring harness/key ignition wire colors
Old May 13th, 2015, 04:09 PM   #27
nickk_pike
what wattage of resistor did you use when you wired 2?
Old May 13th, 2015, 04:12 PM   #28
nickk_pike
and yes, all fuses good, kickstand bypassed, engine is in neutral.
Old May 13th, 2015, 04:12 PM   #29
EMSRacer07
EMSRacer07's Avatar
yeah throw another one on there. Its a matter of what voltage passes through. I cant remember the voltage but 2 resistors 1 watt each did it for me. Hope someone else can chim in and state what voltage needs it to be
Old May 13th, 2015, 04:13 PM   #30
nickk_pike
do I wire them parallel? or in series?
Old May 13th, 2015, 04:18 PM   #31
EMSRacer07
EMSRacer07's Avatar
series. one right after the other. Do you know what voltage and ohm reading your getting after the resistor?
Old May 13th, 2015, 04:20 PM   #32
nickk_pike
unfortunately I do not have a voltage/Ohm meter rightnow.. left it at work
Old May 13th, 2015, 04:22 PM   #33
EMSRacer07
EMSRacer07's Avatar
sure two will do it. If its not the resistor I would think its something else. hmm..... try two and report back asap.
Old May 13th, 2015, 04:23 PM   #34
nickk_pike
okay cool, working on it now.
Old May 13th, 2015, 04:33 PM   #35
nickk_pike
nothing changed, still doesn't work.
Old May 13th, 2015, 04:44 PM   #36
nickk_pike
do I have to have the radiator and everything else plugged in for it to work? I'm at a total loss.
Old May 13th, 2015, 06:25 PM   #37
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Go here to decipher what resistors you have.http://www.digikey.com/~/media/Image...t.jpg?la=en-US
My Cafe Racer Build
My intro post
Old May 13th, 2015, 06:34 PM   #38
EMSRacer07
EMSRacer07's Avatar
brown ones the right ones?
Old May 13th, 2015, 07:17 PM   #39
.............. one more thing, does anyone have any idea on which wires plug into which side of the ignition coils? There is a green side and a black side.. Thanks
Red goes to both (connected to the lower tag in both coils).
Black goes to coil #1 (left when seating in the bike).
Green goes to coil #2 (right when seating in the bike).
Caveat:
The colors are reversed on the old and new gen's wiring diagrams, being the one for new gens wrong.
You could by-pass the CDI, switch, pick-up coil, etc. and test the coils and plugs by themselves:
http://mgaguru.com/mgtech/ignition/ig104.htm
Similar problem:
https://www.ninjette.org/forums/showthread.php?t=128112
https://www.ninjette.org/forums/showthread.php?t=119399
Old May 13th, 2015, 07:27 PM   #40
nickk_pike
I will check tomorrow first thing.
Spark Plug Poll smokinsingle Ninjettes At Speed 15 November 29th, 2015 08:12 PM
Ever have spark plug go bad?? justopelt 1986 - 2007 Ninja 250R Tech Talk 2 April 12th, 2014 01:23 PM
melted spark plug alex.s 2008 - 2012 Ninja 250R Tech Talk 6 October 5th, 2012 12:16 PM
Spark plug reading Racer x 2008 - 2012 Ninja 250R Tech Talk 14 October 7th, 2009 07:53 PM
Spark plug wires diablo250 General Motorcycling Discussion 1 June 11th, 2009 05:23 AM
