October 13th, 2016, 07:04 PM | #1 |
Join Date: Aug 2016 Motorcycle(s): 07 Ninja 250 Cafe Racer Posts: 55
Relocating the Battery
Having reacquired my Cage for DD Duty, and a much larger/faster bike to have fun on, I'm now building my little ninja 250 into a lightweight cafe racer. I'm trying to achieve what is known as the "Glory Hole", which is the large open space in the frame between the seat and swing arm. As you can see I've already relocated all the electronics to the empty space under the tank, and above the carb, but I still have the battery left to relocate.
The obvious would be to fabricate a mount, and mount it atop the strut mount, but that will ruin my Glory Hole. There's are loads of threads on this subject online for other bikes, but I would like to know some actual pregen ninja owners ideas, of where would be the cleanest and safest place to relocate my battery, so I can keep my Glory Hole glorious. Thanks.
'07 Ninja 250 Custom Cafe Racer |
October 13th, 2016, 08:08 PM | #2 |
Just for your consideration:
The original location follows two main rules: 1) The point where shakes/impacts/forces coming from the irregularities of the road are minimum (halfway between both contact patches), because those are the enemies of the internals of any battery. 2) The point close to where the three axis of rotation of the bike cross, because centralization of mass = more agile bike. https://www.ninjette.org/forums/showthread.php?t=208528
October 14th, 2016, 08:04 AM | #3 |
So with that in mind, looks like the only real option is to fabricate a steel box to contain it, and mount it underneath the bike somewhere as close to the center of the bikes mass as possible. I don't see a cleaner or better option myself.
October 14th, 2016, 08:27 AM | #4 |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
You may want to consider getting a four cell Lithium-Iron battery. They're tiny and much easier to hide. Plus they weigh about a pound. I use one for my racebike.
This one has plenty of cranking power for the little Ninjette: http://www.ebay.com/itm/Antigravity-...FSsqA9&vxp=mtr |
October 14th, 2016, 09:20 AM | #5 |
One ugly son of a gun.
+1 on the Li-Fe battery- you can mount it anywhere and if I'm not mistaken they can take quite a bit more abuse than a standard Pb-acid battery. They also can run as a deep cycle, but I cannot attest to how much cranking you can do on them (probably not as much as a lead-acid, but again IDK).
October 14th, 2016, 12:24 PM | #6 |
MOTM - Nov '15
They work fine as long as you don't completely drain them. They charge differently which means that if you do drain them you can smoke 'em if you don't pay close attention while charging with a conventional battery charger. Ask me how I know
There are chargers designed specifically for Li-Fe batteries. Not very expensive (around $30.00) and worth it. |
October 14th, 2016, 12:31 PM | #7 |
EX500 full of EX250 parts
I want to mention the regulator/rectifier here for two reasons.
First, it's really old technology. This exact part number was used on bikes going back to at least '82. Fancy new battery chemistries may not be happy with the output from our clunky old R/R. Do a little research before you drop a ton of cash on crazy new tech to make sure you're not just burning up your money. Second, heat is an issue. The R/R shunts away any extra power (the difference between how much the stator is making and how much your electronics are using) by converting it to heat. When it gets hotter, it gets less efficient, which makes it get even hotter, etc. If you've tucked it away from airflow, you could be heading toward electrical issues. They can fail either high or low - one way just won't charge your battery, the other can overcharge and ruin it. The MOSFET R/R's (model FH### vs. SH###) are more efficient (so they make less heat in the first place) and less affected by heat (so they don't lose as much when they do warm up). They're electrically compatible, so a retrofit is just adapting the connectors and mounting it. They're more durable and stable, but their output still may not match what a non-standard battery likes, so you should still do your research.
October 14th, 2016, 12:31 PM | #8 | |
**edit** Looks like Bill answered my question before I could post it ;-) |
October 14th, 2016, 12:46 PM | #9 | |
MOTM - Nov '15
Also, a characteristic of the LiFe batteries is that when they are cooler they can crank the bike a little bit slower. Not to worry though. The battery gets warmer as the eletricity gets flowing through it and it will actually crank stronger as it gets warmer. They work fine maintaining a charge with the bike's electrical system. It's when you drain them flat or nearly flat and you need to use a battery charger to bring it back to full voltage with a regular battery charger that you can cause problems. No matter if a battery is lead-acid or Li-Fe, any bike or car's charging system is only designed to maintain the charge on a battery that is already near full voltage anyway. They are not designed to charge a weak battery. Invisibill is right about the MOSFET type voltage regulators being the way to go. They are better no matter what type of battery you run. I had a diode type of voltage regulator fail in my SV650 racebike and it overcharged my LiFe battery. It would have overcharged a lead acid battery just the same. I switched to a MOSFET type regulator after that. Last futzed with by tgold; October 14th, 2016 at 12:56 PM. Reason: added comments |
October 14th, 2016, 01:07 PM | #10 | |
October 14th, 2016, 04:07 PM | #11 |
It's possible that floods the engine, but if it does, the carb float valves are leaking too.
October 14th, 2016, 04:15 PM | #12 |
October 14th, 2016, 04:19 PM | #13 | |
MOTM - Nov '15
October 14th, 2016, 04:21 PM | #14 |
Good info. I'm cheap, however, so a it's the vacuum tube in the mouth for me. I don't really drain the carbs too often, I'm REAL close to having them dialed in perfect. Thanks for the tip, though!
October 14th, 2016, 05:35 PM | #15 | |
If too much, it is dangerous because you could bend a connecting rod while cranking up. Please, see this: http://faq.ninja250.org/wiki/What_ca..._I_flood_it%3F
October 15th, 2016, 08:20 AM | #16 | ||
October 16th, 2016, 12:48 PM | #17 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 475
I'm planning to relocate mine to the left side of the engine on a heat shielded bracket. But my ZZR has a full fairing to hide it !
August 18th, 2019, 01:22 PM | #18 |
Join Date: Jun 2019 Motorcycle(s): Tracker Custom Ninja 250r Posts: 5
For the Lithium batteries, do you need an upgraded Regulator/Rectifier to keep them happy? I am running a custom build on a 1995 Ninja 250 and would love to use a small battery
August 18th, 2019, 03:35 PM | #19 |
Hi Mark,
No need to change anything. LiFePO4 batteries's max-charge voltage is actually slightly higher than lead-acid, so using it with factory RR will result in slight undercharging. I've been using small 4-cell battery on my race bike for past 3-years. Still working just fine. Word of caution, many of these batteries do not have over-discharge protection, so leaving lights on for more than 5-10min after stopping will damage them. Last futzed with by DannoXYZ; August 18th, 2019 at 05:28 PM. |
August 18th, 2019, 03:53 PM | #20 |
Amazing! Thanks
License plate relocating | ryoshiggy | 2008 - 2012 Ninja 250R Farkles | 6 | August 25th, 2015 10:31 AM |
relocating the kickstand ? | tac12345 | 2008 - 2012 Ninja 250R Farkles | 6 | August 18th, 2013 09:58 PM |
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
Relocating rear directionals | Sailariel | 2008 - 2012 Ninja 250R Tech Talk | 0 | October 5th, 2008 06:14 PM |
