June 28th, 2019, 05:07 AM | #1 |
Join Date: Jun 2019 Motorcycle(s): KZ400 frankenstein Posts: 3
Front calipers
Hello everybody. I am looking to potentially buy front caliper from a 250 but I have a 6mm rotor, I know the caliper can a least be fitted with a 5mm rotor stock, would my rotor fit or it is possible to modified it to accommodate 6mm?
Thank you very much for you help!!! Regards R1 |
June 28th, 2019, 06:27 AM | #2 |
I have a Ninja caliper on my '72 H2, and that's a 7mm disk. As long as the L-R centering is OK you should be fine. The worst case would be if you bought new pads and they were thicker than would fit and you'd have to thin them a little, but I doubt if that would happen.
Frando Brake Calipers? | GregEvans | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 10th, 2015 05:58 AM |
Pregen Front and Rear Full Calipers | Kruse08 | Items Wanted | 6 | May 11th, 2015 12:44 AM |
Brake calipers | fishdip | 1986 - 2007 Ninja 250R Tech Talk | 16 | December 20th, 2013 11:42 AM |
swapping brake calipers | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | October 5th, 2013 08:08 PM |
Gold Brake Calipers??? | dubojr1 | General Motorcycling Discussion | 40 | January 14th, 2011 07:55 AM |
