Notices
Old July 22nd, 2019, 07:20 PM   #1
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
04 Ninja 250 Carb rebuild kit
It's been a while since I've been here. I'm looking for a 04 Ninja 250 Carburator Rebuild kit. Can anyone point me in the right direction?
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Ninja Rob is offline   Reply With Quote
Old July 22nd, 2019, 07:47 PM   #2
Motorcycle(s): '13 Ninja 300 (white, the fastest color!), '13 R1200RT, '14 CRF250L, '12 TT-R125LE, '15 CRF110F, '13 TT-R50E
@ducatiman
Old July 22nd, 2019, 08:29 PM   #3
I'll be interested in what Ducatiman says, since I have no confidence in carb rebuild kits. The ones I'm familiar with use offbrand parts that are not correct, and cause more problems than they fix.
Old July 23rd, 2019, 05:41 AM   #4
ducatiman
ducatiman's Avatar
^ agreed
These days...."replace everything" (all jets, needles included) is becoming the accepted norm. Brainwashing the lazy with a convenient, easy "solution" to carb "cleaning".
The Far East copy kits containing brass jets and needles are notorious for both wrong parts and improperly sized jets and/or float valves. The companies maximizing their applications (profits) , with near generic fitment. They are NOT using genuine Keihin components unless specifying.
I'm a proponent of properly *cleaning your proper factory jets*. Unless the heads are mauled, there is no reason to replace them. If you DO replace them, use Keihin in correct size.
Otherwise, carb refurb parts needs are minimal....bowl oring (gasket), pilot screw orings, float valves, fuel and vent rail orings (if splitting). What IS needed is employing of correct, efficient methods to clear circuits, followed by careful setup and wet testing prior to replacing the carbs back on the bike.
As these bikes are getting old, splitting and replacing rail rings is advisable.
They do flatten, harden, corrode and leak, as we read about frequently here.
I keep the required, reliable, proven stuff in stock always, OP is welcome to PM.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 23rd, 2019, 11:15 AM   #5
Ninja Rob
Ninja Rob's Avatar
I am going to clean them. However, there are some parts that need replacing like the gaskets, some of the bolts are rounded from the previous owner but I managed to remove them, the parts that push the floats up, and some other parts I don't know the names for. I will put pictures up of the stuff that needs replacing later when I get home.
Old July 23rd, 2019, 05:06 PM   #6
Ninja Rob
Ninja Rob's Avatar
Pics added. Note that I did NOT make any of the damage on the parts, the previous owner maybe didn't have the right patience and tools and you can see how rounded some of the parts are. Especially that gold colored one in the 1st and 2nd pic. I gently removed it with a smaller screw driver ( not the one in the pic) and screwed back in but not all the way so I can easily take it out when I clean/replace the part. Gaskets look worn out too. The floats do not rise to the same height. 3rd pic, I think it's called a drain bolt but that thing is really rusted so I'm going to have some trouble removing it and will probably just replace them. I am also going to replace the 8 bolts that hold each carb closed so those I'll get at home Depot. I got the size from that Ninja250 org website. The other needles and parts are in good condition and just need a good cleaning but some of the parts do need to be replaced. I took the carbs apart and put all back together but these were the damage concerns that I have. Any feedback?
Last futzed with by Ninja Rob; July 23rd, 2019 at 05:13 PM. Reason: Stupid auto correct on phone
Old July 23rd, 2019, 05:42 PM   #7
ducatiman
ducatiman's Avatar
I'll try to address all your comments.....the brass colored screw in pic 1 and 2 is the pilot screw (adjusts idle fuel mixture) You need to replace the tiny oring which resides deep inside....also a spring and tiny washer then oring (in that order) should be present on each screw.
Pic 3 is bowl drain screw, a 3mm allen to remove
Pic 4 flattened bowl gaskets (imperative to replace both)
Pic 5 float valves, RH one has come apart (imperative to replace both)
Pic 6 whacked out, high float levels carb on LH side of pic due to broken float valve. You must replace float valves, clean seats and adjust.
of course, every screw needs replacement. I use stainless buttonheads, don't even need washers.
What shape are the diaphragms in?
You plan on splitting them to enable replacement of the rail orings? Also enables access to inspect the vacuum hoses between. Then of course you've got to remove the choke plungers to access the enrichener circuit...then inspect/service the decel valve.. more and more.
Those carbs are pretty rough...consider a refurbed set.
Custom Carb Service
Old July 23rd, 2019, 06:14 PM   #8
Ninja Rob
Ninja Rob's Avatar
Where can I get a quality refurb set? I'm trying to get it running and then sell in the near future. I'm thinking it'll start getting expensive to continue to own it. I'm saving for a newer bike. 😁 I didn't mind learning how to take apart and clean the carbs. It has actually been a good experience so far.
Old July 23rd, 2019, 06:53 PM   #9
ducatiman
ducatiman's Avatar
i'll check my stuff and get back
Custom Carb Service
Old July 28th, 2019, 06:53 AM   #10
Ninja Rob
Ninja Rob's Avatar
Got anything?
Old July 28th, 2019, 08:14 AM   #11
ducatiman
ducatiman's Avatar
I'd need to refurb a set....take me a day....$175 shipped
OR could refurb yours for approx $140 shipped (provided no peripheral diaphragm/slide damage or major missing/broken parts)
I do have emergency salvage spare parts if needed, so no delays.
Honest, quick, efficient....I'm sure you've seen my work on the forum here.
Anyways...a couple of options offered ....PM if you'd like to go forward.
Custom Carb Service
Old July 28th, 2019, 05:03 PM   #12
Where can I get a quality refurb set? I'm trying to get it running and then sell in the near future. I'm thinking it'll start getting expensive to continue to own it. I'm saving for a newer bike. �� I didn't mind learning how to take apart and clean the carbs. It has actually been a good experience so far.
Here's examples of ducatiman's most excellent work. You can't go wrong with his refurb service or pre-rebuilt set of carbs. Mine looked liked this before I sent them to him. They came back pristine and bike ran like brand-new!!! I've gotten multiple carbs done over the years and they all came back perfect!
If you really want to learn about rebuilding carbs, search for "clean carbs ducatiman" and see numerous threads on subject. You'll need to invest in some equipment such as ultrasonic cleaner, caustic radioactive solvents, micro soda-blaster, 10000psi compressor, etc.
Last futzed with by DannoXYZ; July 28th, 2019 at 06:11 PM.
Old July 28th, 2019, 05:55 PM   #13
ducatiman
ducatiman's Avatar
@DannoXYZ thank you for kind words.
A long, hard day of yardwork....I've got carb stuff laid out, ascertaining what is needed to get them up to standard. May take a snooze followed by a late night work session.
Custom Carb Service
Old July 29th, 2019, 11:36 AM   #14
ducatiman
ducatiman's Avatar
posting as promised, this set ready to go
105 main, 38 pilot , N16I needles, pilot screws 2.5 turn, throttle plates synched, idle set very close (you'll reset anyway to your chosen RPM when warmed)
You'll need to switch over your fuel hose and rail strainer (if present)
PM comin'
Custom Carb Service
Old July 29th, 2019, 01:00 PM   #15
Ninja Rob
Ninja Rob's Avatar
PM comin'
Why do they need to be switched over? I'm asking because I don't know why. Is it so they can fit in the bike or something related to fitment?
Old July 29th, 2019, 01:20 PM   #16
ducatiman
ducatiman's Avatar
sometimes folks leave their fuel lines and rail strainers on, sometimes not.
These ...not. I don't need fuel lines to be shipped when I clean carbs.
Simply pull off your existing fuel hose and swap it over to the refurbs upon installation.
Custom Carb Service
Old July 29th, 2019, 03:29 PM   #17
ducatiman
ducatiman's Avatar
petcock if needed, salvaged, brought back from the dead
note obvious missing screen...has been relocated internal...will be fully functional provided no rocks, stones, birds, tree branches or small children are finding their way through the tank.
Custom Carb Service
Old August 10th, 2019, 12:06 PM   #18
Ninja Rob
Ninja Rob's Avatar
My Ninja is working again. Took a few tries to get it started and spent a while in the Triple digit temperatures of Texas but it's working now. Thank you ducatiman for your carb service. Not sure how to @ someone.
Last futzed with by Ninja Rob; August 10th, 2019 at 05:00 PM.
Old August 10th, 2019, 01:41 PM   #19
ducatiman
ducatiman's Avatar
just for you.....
Custom Carb Service
08+ Carb Rebuild Kit EternalNewb Items Wanted 3 April 8th, 2015 11:06 PM
Recommend me a Carb Rebuild Kit FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 8 January 21st, 2015 10:10 AM
Can't find carb rebuild kit? redeiko0713 2008 - 2012 Ninja 250R Tech Talk 17 September 28th, 2013 09:32 PM
