Old July 25th, 2019, 06:09 PM   #1
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Cluster Problems Solved
A while ago I posted that I was having problems with an intermittently working cluster, the tach, the speedo, and the fuel gauge all worked intermittently on a 2010 Ninja 250, with over 20k miles on it.
This is odd because the Tach and Fuel gauge are electrical, but the Speedo is completely mechanical, and can function without the bike running even.
After testing with a multimeter, checking all connections were solid, and even replacing the fuel level sensor, the front wheel seedo sensor, and the speedo cable, it still didn't work.
I bought a used cluster that was supposedly working, with about 27k miles on it locally.
All of the component at this point, the harness, the cluster, the speedo sensor, the speedo cable, the fuel level sensor, all had been replaced at that point with no change.
Having two clusters, I disassembled the cluster that came with the bike for further inspection into the problem. What I found was that the needles themselves were sticking to the stops on the gauges, and that if you tapped the gauges sometimes they'd come unstuck. I tore apart the cluster I'd bought and found the same exact problem. After unsticking the needles and lubing all mechanical components in the speedo, I reinstalled and now everything works perfectly fine with no problems whatsoever.
TL;DR, 2008-12 Ninja 250 clusters with 20k miles are apparently prone to the needles sticking to the stops if left outside in the sun for long periods of time during their lifetime.
I've added a photo showing the marks on the needles where the stops had melted an indentation and paint from the stops was left on the needles.
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Old July 25th, 2019, 08:03 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
What did you use to lube the gauges?
I've heard some old timers use synthetic sperm whale oil (no joke).
Old July 25th, 2019, 08:21 PM   #3
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Lol does it come from Synthetic Whales?
I actually googled it, it comes from the Jojoba plant, which apparently is almost identical in chemical structure to Sperm Whale Oil.
No, I'm not that fancy, and it's just a Ninja 250. Not a fancy vintage or antique restoration.
I just cleaned it up with WD-40 and put some generic grease on the gears.
YouTube
[motogp.com] - Rabat: “The set up solved a lot of my problems” Ninjette Newsbot Motorcycling News 0 August 30th, 2017 08:10 AM
[motogp.com] - Rossi: "We think we've solved the problems" Ninjette Newsbot Motorcycling News 0 May 8th, 2017 11:41 AM
[motogp.com] - Lorenzo: “Little by little we solved these problems” Ninjette Newsbot Motorcycling News 0 April 22nd, 2016 09:21 AM
[motogp.com] - Marquez: “We have solved a few of the problems” Ninjette Newsbot Motorcycling News 0 June 12th, 2015 10:50 AM
