Old July 26th, 2019, 09:16 AM   #1
Dbo03
Motorcycle(s): 1999 Ninja 250R
Cam/Chain/Rocker ?
Bike was running just fine- turned it off and ran into store.. came back out and tried to start it and it would crank over but wouldn't start- had to use full choke AND 3/4 throttle to get it going and heard tapping/slapping noise big time.. the speed of the noise was same as rpm's (more throttle-faster the tapping) and won't run on its own. I tried resetting the CCT but it didn't do anything to help.
I'm new to bikes, but I work on cars n trucks etc. (Just not anything internal on engines)
I am a spunge and want to learn- so let me know what ya think I got goin. Thx
(1999 Ninja 250R)
Dbo03 is offline   Reply With Quote
Old July 26th, 2019, 09:35 AM   #2
Hello Dustin, welcome.
I'm only guessing without an audio recording of the noise, but needing full choke and that much throttle could mean something as simple as clogged carbs, with the noise coming from the open throttle sucking air. Or something mechanical could have let loose inside the engine.
Old July 26th, 2019, 12:55 PM   #3
Dbo03
Thx for getting back to me'
Carbs cleaned and adjust recently and drove just fine to the store and then bam! It's so weird.. the noise sounds like a piece of bamboo with a flat end on it that's going around with the crank- slapping on everything it touches and speeds up right along with the rpms..
... And that's just about the oddest description Ive ever given to date. Lmao
Old July 26th, 2019, 01:55 PM   #4
ducatiman
ducatiman's Avatar
Turning bike off...then switching on shortly after with issue...weird circumstance. This happened immediately after you were in carbs?
As thats the last place you were in prior to this issue...an internal carb review is called for.
Desperate start requiring choke and open throttle to start indicate something going on in those carpotata's.
Suggest to verify both carb diaphragms are properly seated and intact...no rips or tears.
Floats are, um...floating?
Did you leave something loose within the carbs which took awhile to loosen further or fall out to create the issue?
A severely out of synch carbset *could* make nasty noises ...1 cylinder running, the other fighting against it, being dragged along.
Bottom line, I'm suggesting to review your carb work first, eliminate or correct any errors there prior to ripping your engine apart.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 26th, 2019, 03:37 PM   #5
Timing-chain may have jumped a tooth.
- Do compression test.
- Verify cams are sync to crank properly
Old July 26th, 2019, 04:49 PM   #6
Dbo03
I rode the bike for several weeks b4 this happened.. I fine tuned it every couple days or so just to see if I could better it. It's almost like the chain must have been very loose and maybe the noise is the chain riding over the top of the sprockets? I read however that I should rotate the engine manually since I reset the CCT? I haven't done that yet-
P. S. Thanks for taking the time to help me out 'its very much appreciated!
Old July 26th, 2019, 05:14 PM   #7
Yes, safest to turn engine over 720-degrees by hand to make sure no valves are contacting pistons. Take valve-cover off as well and verify cam-sprockets line up properly at TDC.
Old July 26th, 2019, 06:35 PM   #8
ducatiman
ducatiman's Avatar
that's a valid precaution @DannoXYZ
bike running fine...turn key off for his stop. Come out turn key on, start attempt....cam chain/tensioner/valve timing issue instantly during (or caused by) startup? Wow.
Weird scenario...
Custom Carb Service
Old Cam Chain Tensioner akima 2008 - 2012 Ninja 250R Tech Talk 0 February 1st, 2017 06:41 AM
Is this a loose cam chain? Cra1g 1986 - 2007 Ninja 250R Tech Talk 7 August 30th, 2016 06:53 PM
Changing cam chain scorch 2008 - 2012 Ninja 250R Tech Talk 17 April 28th, 2014 08:46 AM
stretched cam chain alex.s 2008 - 2012 Ninja 250R Tech Talk 22 June 28th, 2012 06:52 PM
